Old 08-03-2012, 05:22 PM   #1
sesmls
Drives: DGM BRZ Limited, 05 Baja Turbo
Panel Removal for rear speakers?
Can anyone tell me how to remove the rear interior panels so I can replace those 3.5" speakers back there? I looked around the various threads and couldn't find anything that specifically gives a step-by-step on removing those particular panels.
Thanks for your help.
sesmls is offline   Reply With Quote
Old 08-03-2012, 05:26 PM   #2
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
I don't have a step by step nor do I remember exactly how I did it since it was almost 2 months ago, but it was very easy to get apart and back together. Just lightly pull on the panels and see what holds it together, I dont remember any screws im pretty sure its just a bunch of clips.
Flat Black VW is offline   Reply With Quote
The Following User Says Thank You to Flat Black VW For This Useful Post:
sesmls (08-04-2012)
Old 08-03-2012, 06:29 PM   #3
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
I don't know if it's absolutely necessary, but when I pulled mine I had the rear seats out as well. The seats are easy enough to remove:
1) fold down seat-back
2) loosen the bottom flap of carpet by pulling to the side to release the button clips
3) remove 12mm bolts from either side
4) remove seat back from vehicle
5) remove 10mm bolts from front of seat bottom
6) push down and back on back of seat bottom to release from hook on the frame... this is the hardest part of removing the seats.
After the seats are out the bottom of the side panel is much easier to access. Just pull out on the bottom and work around the edge to pop the clips out, then pull straight up at the window to remove.
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
The Following 2 Users Say Thank You to Moshpit37 For This Useful Post:
Prodigalson (12-31-2017), sesmls (08-04-2012)
Old 08-05-2012, 09:26 PM   #4
drifter
Drives: truck and old car
Do they have to be replaced with the same size speakers? Going to do the same, wondering if I can go wth slightly bigger back speakers. thanks.
drifter is offline   Reply With Quote
Old 08-06-2012, 12:46 AM   #5
sesmls
I saw someone here who had bigger speakers installed, using a panel of MDF behind the plastic panel...can't remember where I saw it.
I'm going to go with the 3.5" Infinity Kappa speakers, and install Earthquake SWS 6.5" Shallow-mount Subwoofers in the doors.
The Following User Says Thank You to sesmls For This Useful Post:
stea1thbear (08-14-2013)
Old 08-07-2012, 12:03 PM   #6
sesmls
Well, I got the rear panel off and in so doing, two of the little white plastic trim fasteners that slide into the brackets on the back of the panel and snap into the holes in the metal came loose and flew off into the netherlands of the frame (e.g. the hollow area below the door sill, I think). Any ideas on how to fish those out of there?
I can get new ones easy enough at an auto parts store, but would rather not have them rattling around down there.
Old 08-14-2013, 05:56 PM   #7
stea1thbear
Drives: Scion FR-S Firestorm
How do the Earthquake SWS 6.5" sound in the doors? What frequency are you crossing them over at? Did you put any sound deadening in the doors? Interested in doing the same, thanks in advance.
stea1thbear is offline   Reply With Quote
Old 08-16-2013, 08:26 PM   #8
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
He's probably done by now but for future reference:
[ame="http://www.youtube.com/watch?v=LytAyXbgS5w"]Scion FR-S / Subaru BRZ | System 400+ Installation - YouTube[/ame]
skip to 3:13 for rear quarter panels
This video is a pretty good guide in disassembling all the panels.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
The Following 4 Users Say Thank You to l0aded For This Useful Post:
bama_brz (10-03-2014), Black Tire (08-08-2014), EndlessAzure (04-13-2020), stevo_12v (08-26-2013)
Old 08-01-2014, 07:43 PM   #9
Dangerboyjohn
Drives: White out 2014 FR-S
I know this is a really late reply to Sesmis, but if anyone else is having a problem with lost parts down a black hole: If you can hear them or know where they are but can't reach them, spray some foaming insulation like Great Stuff down the hole to just immobilize them in place.
Dangerboyjohn is offline   Reply With Quote
Rear seat removal? Shizuma BRZ First-Gen (2012+) — General Topics 34 04-01-2013 04:36 AM
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 07:31 PM
CF wrapped dash panel Z0rr0 Cosmetic Modification (Interior/Exterior/Lighting) 34 08-29-2012 10:32 PM
Is this what they mean by panel fitment issues? ahquit Issues | Warranty | Recalls / TSB 7 08-21-2012 04:19 PM
Rear speakers, problem? Style Electronics | Audio | NAV | Infotainment 8 07-15-2012 09:59 PM
