Old 07-09-2025, 01:55 AM   #1
callisto
Drives: 2019 Subaru BRZ
Post 18-19 MT EU have a more detailed DI/PI ratio tune than 17-20 JP/US
2018 MT EU (ZA1JQ00G) and 2019 MT EU (ZA1JS20G), received a much more detailed DI/PI ratio tune (direct/port injection) than either US or JP markets received at any time during gen1. Perhaps this was in response to new emissions restrictions landing in the EU around that time? The tuning tables are perhaps incompatible with K00G since they're the newer expanded kind, but duly noted for those who wish to study and pass judgment on what might be the intended effect.
Relevant tables that changed, based on a detailed reading of as much of the code as I could find and all K00G/S10C-documented Injector Ratio tables:
  • Total Injection Ratio Port Warm - and copied to Cold/Hot in full, which no other series can cope with
  • PI Ratio ECT Compensation
  • PI Ratio ECT Compensation (Load)
  • PI Ratio Thresholds
  • PI Ratio Thresholds (Load)
  • PI Ratio Thresholds (RPM)
  • PI Ratio Thresholds (Unknown) - it's a default buried in the code somewhere
  • GDI Firing Angle (all five)
Screenshots attached; either left/middle/right, or top/middle/bottom, are S20G/the-difference/V00C (I haven't mapped out Q00G yet but it has the exact Warm table as MY2019 EU S20G). Note that I haven't researched at all how much of any of this can possibly be applied to a K00G-derived tune; I suspect I'll need to release a K00G expanded variant with larger tuning tables to support that. Someday-next!
Various notes: I've only considered EU, JP, US. In the screenshots, "V00C00G v1" is the pane showing the changes 18-19 EU makes relative to 17-20 JP/US. I'll release S10C.xml v4 soon with the PI Ratio table, but I have a lot of busywork left to do on S20G/U01A/V00G before I can release those. If there's other tables related to DI/PI that I should evaluate for differences, let me know.
EDIT: There is also a specific change to all of the GDI firing angle tables that is probably relevant to anyone reading this post, as DI/PI work in concert on this engine to manage cylinder cooling. S20G/V00C comparison image added, showing the new data present in all S20G tables. (2025-11-10)
Last edited by callisto; 11-10-2025 at 05:36 AM. Reason: add GDI firing angle change
callisto is offline   Reply With Quote
The Following 3 Users Say Thank You to callisto For This Useful Post:
RedReplicant (07-10-2025), Tatsu333 (07-19-2025), tomm.brz (07-24-2025)
Old 07-16-2025, 03:46 PM   #2
gpvecchi
gpvecchi's Avatar
Perhaps because the EU spec require 98 octanes fuel? JP require Premium fuel, so 96 octanes. The US are probably even lower.
Old 07-18-2025, 05:56 AM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Us spec recommends 93 AKI should should be 98 RON.
Minimum octane 91aki.
RToyo86 is online now   Reply With Quote
Old 07-19-2025, 10:59 AM   #4
Tatsu333
Drives: 2020 BRZ Sport Tech RS
It'd be interesting to see if there's any noticeable difference in day-to-day driveability between the two configurations. I might have a look at what I can apply through ECUTEK and give it a go...
Tatsu333 is offline   Reply With Quote
Old 07-19-2025, 11:10 AM   #5
callisto
Agreed! I'd love to know if it has any noticeable effect for anyone else. My last year of testing was U01A with injector and timing tables from S20G, but once I mapped enough ECUs to compare and find out that I'd reverted the U/V improvements to timing maps, I'm now doing a year of testing with just the mods I posted above to V. (Note that if you're on K00G or older that you may have to remap the table to fit, I think this is one of those that expanded to provide more tuning fidelity in the facelift era?)
The Following User Says Thank You to callisto For This Useful Post:
Old 07-23-2025, 12:20 AM   #6
tomm.brz
Drives: brz 2017 hksv2
it's just emission related. nothing more
the new EU with so much PI instead of DI runs worse, specially with 95RON
less DI runs just better and less knocky
93AKI of US is much more quality than 98ron and even 100ron of europe.. i'd say at least 102 ron
that's why US rom have more ignition timing and more power
k00g doesn t have full closed loop fueling, from Q00G EU they implemented full closed loop same as US tunes, with expanded PI tables... still, they run shitty, US tunes are much better, and still K00G is more stable and runs better than >Q00G
When i can, i always convert to k00g, much much better
for shitty fuel quality , car has more power (because it knocks also less) with more DI than PI.. i use 10% max at full load
for better fuel quality you can raise PI to 20-25% or even 30% for e85, it gains a little power with same ignition timing
Tatsu333 (07-24-2025)
Old 07-23-2025, 05:50 PM   #7
callisto
That is excellent news, thank you for confirming (not sarcastic!), I appreciate the details and will study Q00G next.
GT86 2018 Driver side is lower than my passenger side/ lopsided Sioux Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-31-2022 11:18 PM
Why is a Stage 1 tune better than stock? Zinnober Software Tuning 9 08-22-2021 07:05 PM
What should I do if car has been unused for more than 5 months dazhbucked Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 03-29-2021 08:19 AM
BRZ 2018 AT to MT gear ratio Septor Engine, Exhaust, Transmission 22 01-21-2019 03:42 PM
Does anybody know if the tune from the vortech is better than the ecutek? Frsexxxy Forced Induction 16 04-08-2013 11:53 AM
