Old 07-31-2022, 05:59 AM   #1
Sioux
Drives: Toyota 86 2018
Exclamation GT86 2018 Driver side is lower than my passenger side/ lopsided
The first photo is the driver's side and appears to be a positive caster.
- slanted/tilted to the right
The passenger side appears to be a neutral caster.
- completely vertical 0
The car is lopsided so the passenger side is higher than the driver's side.
The steering wheel is tilted to the right a bit when driving straight and the car does pull to the right.
Do you guys think that the neutral caster is causing the car to pull to the right and look lopsided? Or could it be something else ?? A second opinion would be nice!
The car drives perfectly fine nothing out of the norm, but i cant stop thinking about how lopsided the car looks from the front
I have seen the other forums but nothing talking about the caster possibly affecting the height of the car :/
Thank you!
Sioux is offline   Reply With Quote
Old 07-31-2022, 07:20 PM   #2
glhs386
Drives: 2014 FR-S Monogram
Something is horribly bent on one side or the other. Check the lower control arms, struts and upper strut mounts. As another (albeit less likely) possibility, I have a friend with an E36 that had a similar problem, turned out the previous owner installed one eccentric upper strut mount in the wrong orientation.
glhs386 is offline   Reply With Quote
Old 07-31-2022, 07:48 PM   #3
Sioux
Originally Posted by glhs386 View Post
Something is horribly bent on one side or the other. Check the lower control arms, struts and upper strut mounts. As another (albeit less likely) possibility, I have a friend with an E36 that had a similar problem, turned out the previous owner installed eccentric upper strut mounts in the wrong orientation.
Yea I’m going to take a look soon, do you think a wheel alignment would correct it if nothing is bent ? So that the struts are angled the same again? Thank you btw!
Old 07-31-2022, 07:52 PM   #4
glhs386
Caster is non-adjustable, an alignment will fix nothing without replacing whatever part is causing the problem.
Old 07-31-2022, 08:54 PM   #5
Sioux
Bro, I just got home and checked them again they both have a positive caster, car has been sitting all day.
Uhhhh it’s still lopsided… I’ve read on other forum’s that the air in the tire can make them look different apparently.
Maybe the passenger tire has more air and once it gets hot it makes the caster into a neutral position. Or drive side has less. Hence maybe explaines lopsidedness hopefully but seems far fetched.
Either way ima check everything throughly.
I really do appreciate your thoughts ! Once again thank you!
If anyone else would like to share your opinion please feel free to do so!
The Following User Says Thank You to Sioux For This Useful Post:
glhs386 (07-31-2022)
Old 07-31-2022, 11:08 PM   #6
strat61caster
strat61caster's Avatar
A god alignment shop will tell you what’s broken. Those two pictures look like something is broken.
ineedyourdiddly
Old 07-31-2022, 11:18 PM   #7
Sioux
Yea I do plan on taking it to a shop for them to take a look. The thing is that now that the car has been sitting all day the struts look the same both have a positive Custer. Both now look like the first picture very odd.
brz alignment, lopsided, suspension springs frs, wheel alignment
Heat is hot on Driver's side, cold on passenger's StreetHound Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 01-07-2020 03:01 PM
Heat is hot on driver side and cold on passenger. Peanrocks Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 11-30-2018 12:55 PM
Need left driver side lower control arm jrsd1 Want-To-Buy Requests 0 08-21-2015 11:38 AM
wtb brz driver and passenger side sun visors nerdgsr Want-To-Buy Requests 3 04-29-2014 04:28 PM
WTB: FRONT LOWER CONTROL ARM (PASSENGER SIDE) Filipino Royale Brakes, Suspension, Chassis 0 04-20-2013 06:38 PM
