Drives: Subaru BRZ 2014
What should I do if car has been unused for more than 5 months
Hey everyone I wanted to ask y’all for your tips. My car has been unused for more that 5 months, it has been covered with a high quality car covered and with the battery unplug, but standing still on dirt. If you guys can help me, what are things I should look for before using my car again?, what are the prone things to messed up or what should I do?.
I also heard that you can prime the oil and fuel pump by pressing the clutch and gas pedal and turning the vehicle, but how exactly does this work?, and what should I left off first? Sent from my iPhone using Tapatalk |
30 minute maintenance
Drives: My18 wrxsti
pull the fuel pump fuse or relay out crank the car until the oil oil light goes out. put it back in turn on reds but dont start. turn off and then normal start. Check fluids etc first of course
| The Following User Says Thank You to gen3v8 For This Useful Post: | Ultramaroon (02-14-2021) |
Drives: 2014 FRS Ultramarine
Pretty sure you can cut fuel simply by staying at full throttle while cranking can't you? Same idea though, crack the engine with no fuel to get oil circulating before trying to start it.
Sent from my ONEPLUS A5010 using Tapatalk |
not playing cards
^^ this ^^ Can read about it in the owner's manual. I think it's called the flood-clearing mode.
Except the evil side of this technique is that while stepping on the clutch, any existing lubrication is being squeezed out of the thrust bearings. Out of principle, I've been bypassing those stupid clutch safety interlocks ever since they first appeared. Can only do that with a key start. Just fire it up. It'll be fine.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | humfrz (02-14-2021), The Red One (02-15-2021) |
#5 | |
Thanks!, I’m just going to start it up since my car is keyless, I hope everything goes fine Sent from my iPhone using Tapatalk |
Yep, check the oil level, air up the tires, charge up the battery - then fire that motha up -
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | soundman98 (02-14-2021), The Red One (02-15-2021) |
#7 | |
Drives: My18 wrxsti
But the OP does say car not just engine....So... Last edited by gen3v8; 02-14-2021 at 12:39 PM. Reason: Re read |
| The Following 2 Users Say Thank You to gen3v8 For This Useful Post: | humfrz (02-14-2021), Ultramaroon (02-14-2021) |
#8 | |
I WAS going to you last night for your lack of reading comprehension, but I'll cut you a brain fart on that one.
| The Following User Says Thank You to humfrz For This Useful Post: | gen3v8 (02-15-2021) |
Famous Potatoes
Drives: '15 ultramarine
I would start it and drive It like I stole it. It is a fucking twin.
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | Mr.ac (03-29-2021), soundman98 (02-15-2021) |
#10 |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
I've let mine sit for two weeks while on vacation a few times before. 14 FRS for reference. On one trip, it was a bit rattly for about 1-2 seconds before the oil pressure kicked in. Don't wick the throttle and send your bearing loads skyrocketing.
I've had it do on it my other boxer subarus over the years as well for reference. Never more than just the usual bit of tiny shiny bits in the oil as usual. Actually, on my FRS, cleanest oil changes I've ever seen in regards to the shiny bits. |
#11 |
These and all other cars can sit for weeks and months before they are even owned. They do not go through any special start up procedures when they do get started.
It is one startup and even at it's possible worst it took .00001 minutes off the life expectancy of the car.
| The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (03-03-2021) |
#12 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Flush the squirrels out of the CAI and you should be good to go.
"I gotta rock." -- Charley Brown |
| The Following 2 Users Say Thank You to bcj For This Useful Post: | Overdrive (05-29-2021), soundman98 (03-03-2021) |
#13 |
Mine sits seven months over the winter every year. Check battery tires fluids and start. So far no problems i know of. Bought it new in 2013.
EDIT I do use a good quality battery maintainer. EDIT2 I add Stable and fill the gas tank. Last edited by ls1ac; 03-04-2021 at 08:41 PM. |
| The Following 2 Users Say Thank You to ls1ac For This Useful Post: | soundman98 (03-03-2021), The Red One (03-04-2021) |
#14 | |
ProCrastinationConsultant
| The Following 5 Users Say Thank You to soundman98 For This Useful Post: | ddevl_86 (03-06-2021), Dzmitry (03-04-2021), NoHaveMSG (03-04-2021), Tcoat (03-04-2021), The Red One (03-04-2021) |
| What do you guy's do with the unused oil? | lupindub | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 31 | 02-14-2016 04:36 PM |
| FS: NEW UNUSED Bridgestone Potenza RE-11s set of 4. | BRZZZZZZZZZZ | Canada Classifieds | 3 | 05-14-2014 08:47 AM |
| For Sale: SPC LCA ***NEW*** unused | dkx64 | Southern California | 0 | 03-21-2014 12:05 PM |
| SOLD - 3 BAR Map sensor NEW, unused | Amadeus | Engine, Exhaust, Bolt-Ons | 2 | 08-19-2013 12:25 PM |
| Storing an unused car? | #87 | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 02-21-2012 10:51 PM |
