Old 07-10-2025, 04:05 PM   #43
geraldjust
Drives: MR2, Sliver BRZ
Originally Posted by smoltz View Post
@TRS @geraldjust
Either of you make any headway on this?
somewhat. on gen1 and gen2, it seems that the primary software limit is actually the amount of current the driver can pull. this is most likely done because of the cable thickness being used in the wiring. drawing more most likely can lead to toasty cables lol. on gen1 the driver memory can be reprogrammed so i will try and look for the current settings. but on gen2 your out of luck.
theirs a better chance to try and retrofit a WRX 15-20 steering rack. the current limits is nearly double on that.
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 07-10-2025, 09:15 PM   #44
smoltz
Drives: 01 911 Turbo, 03 G500
I like toasty wires and I have a gen 1... :-)
smoltz is offline   Reply With Quote
Adjusting AFR with Engine Load Compensation (instead of Load Limits) Tor Software Tuning 33 08-17-2021 09:58 AM
ISSUE: 1900-2000 RPM Shutter/Shaking (Free load) Neurytic Issues | Warranty | Recalls / TSB 29 11-22-2020 11:19 PM
Steering issue? edrokone BRZ First-Gen (2012+) — General Topics 6 05-16-2020 03:58 AM
Possible Steering Issue ? TJB_902 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-24-2015 02:38 AM
Steering wheel issue Khalis Issues | Warranty | Recalls / TSB 1 05-04-2013 02:19 AM
