Old 06-30-2025, 06:49 AM   #1
Eaton PSI
Drives: 2013 86
Found a ball bearing on my magnetic drain plug!
I changed the oil in my gearbox tonight (GT86 2014 M/T) , and among the fine metal paste on the drain plug magnet was a 5mm ball bearing!
Anyone have any suggestions as to where this could have come from?
Gearbox has been working fine. I had a mechanic change the gearbox and diff oil at least 2 years ago as I was to lazy to do it myself. I don't know what oil they used, I think the shift was noticeably better prior to the oil change.
I put penrite in it tonight and it seems to shift well.
I've never seen inside one of these gearboxes but I don't imagine there's many places a ball bearing could fall out of and not cause serious problems...
I did see on the bottom of my crappy chinese pump that it uses bearings for check valves, maybe ball came out of the last guys pump? I don't know
2014 GT86, 2.2L big bore, harrop supercharged
Eaton PSI is offline   Reply With Quote
Old 06-30-2025, 09:18 PM   #2
Luns
Drives: 2017 GT86
Shift detent ball.
Each synchronizer hub has three of these balls (and springs) between the hub and sleeve. It's not uncommon to have one or two pop out, and get away with the remaining ones. If shifting isn't horrible (and maybe more importantly, it's not slipping out of gear on its own), it's something you can forget about.
https://www.ft86club.com/forums/showthread.php?t=139737
Luns is offline   Reply With Quote
The Following User Says Thank You to Luns For This Useful Post:
Eaton PSI (06-30-2025)
Old 06-30-2025, 10:02 PM   #3
Eaton PSI
Drives: 2013 86
Man, it's crazy that somehow its possible for that to happen. And equally crazy it makes no difference to the operation of the gearbox! I might look into finding another box and getting it rebuilt in case of failure.
The Following User Says Thank You to Eaton PSI For This Useful Post:
Wally86 (07-01-2025)
Old 07-01-2025, 03:28 AM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I believe one of the mods Jacks Transmissions does to these is to prevent this from happening. It is from shifter overtravel from what I understand.
Old 07-01-2025, 10:13 AM   #5
smackrel
Full Throttle!
Drives: 17 CBSP Limited PP
Glad that someone was able to offer information quickly on this one, that would have had me freaked out as well.
Do our gearboxes have a magnetic drainplug from the factory?
smackrel is offline   Reply With Quote
Old 07-03-2025, 07:41 PM   #6
RedReplicant
Drives: None
My Jacks broke, allowed one of these balls out, and the transmission ended up completely jammed in third gear.
I guess in some order the ball can pop out, the hub breaks next to the synchro ring tab, you get some overtravel of the shift fork ring whatever it is called, the synchro can rotate, and it can all get kind of stuck in a position where the shift fork ring won't move due to alignment of everything.
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
callisto (07-10-2025)
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 08:36 PM
<FS> Project Kics magnetic drain plug (Mag-1 & Mag-3) $15 shipped each mav1178 Mechanical Maintenance and Tools 2 12-17-2014 07:48 PM
Magnetic oil drain plug, effective? BRZPDX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 02-17-2013 12:59 AM
Greedy Magnetic Drain Plug USMC -FRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 02-10-2013 07:04 PM
GReddy Magnetic Drain Plug BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 01-05-2013 11:19 PM
