Old 04-26-2025, 08:20 AM   #519
tomm.brz
Drives: brz 2017 hksv2
Originally Posted by kcratos View Post
So, I replaced all 4 OCVs , reset code, it came back within an hour of driving around. The idle At supper low rpm takes a second to adjust. so it still shuts off on me at times, like 2% of the time when dropping into neutral or quickly clutching in.
Thinking what to do next.
also with the code showing I cannot shut off traction control.
well... take the ocvs swap as good maintenance...
next step is doing the cam shaft sensor clearance TSB by shimming
i tried attaching the pdf
next step again is changing a cam gear/sprocket, or more of them but probably just one has got faulty. This is probably what is causing the lag in vvt targeting and the limp mode with dtc
Old 04-28-2025, 05:28 PM   #520
kcratos
Drives: minimalist
thank you for you reply,
To my understanding if something inside (Sprocket or chain )was to be worn out it would not run smooth and you would hear that something is off. in my case the engine sounds as it always did. It sounds healthy throughout the rev range.
What if the stalling issue that I have is due to to the engine being in this limp mode? maybe its not giving proper gasoline to air ratio, (cuts it off or limits it)?
This service bulletin doesn't list the code p0016 I'm not sure its for same issue.
But their solution is to put a washer for the sensor that measures for this code. the sensor that I already replaced. It seems too good to be true and doesn't make sense how it could be a solution. Where do I even find this shim or spacer?
kcratos is offline   Reply With Quote
Old 04-29-2025, 05:07 AM   #521
tomm.brz
don't know what to say.. if you search for p0016, here anyone has fixed that by replacing the cam gears inside the cover... p0016 instead of p0017 says you that only one bank is affected, but can't tell you which
it's probably your case too.
Old 06-06-2025, 11:04 AM   #522
kcratos
Drives: minimalist
Thank you for your reply,
if they replace internals, Why do they still need to replace the ECU afterwards?
(I've been driving the car little less but it drives fine, besides not being able to turn off traction control and i think its in limp mode. Its ok for commuting though. I fully reset ecu by unplugging the car, the code came back. problem still persists. )
Old 06-08-2025, 02:24 PM   #523
Lantanafrs2
Drives: 2013 frs red
Cam chain or tensioner issue?
Lantanafrs2 is offline   Reply With Quote
Old 06-08-2025, 05:14 PM   #524
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It’s because of the way the ECU relearns initial cam position value on startup. If you have any of the cam correlation codes for too long it gets out of range of the ECU’s ability to relearn the values. It’s stupid, but it’s what makes a Subaru a Subaru.
blsfrs (06-09-2025)
Old 06-10-2025, 03:50 PM   #525
kcratos
Drives: minimalist
no issues, my car drives fine once it learns the fuel to air ratio. unfortunately that's when the p0016 code comes up.
Old 07-01-2025, 11:04 AM   #526
kcratos
Drives: minimalist
For the sprockets, are left and right sprockets the same part numbers?
is there 4 or 2 total I need?
bc in photos and videos of people working the all sprockets look the same but In those amazon ebay kits the left and right sprockets looks different.
also how would u recommend getting everything?
I was thinking rock auto for cloyes chain and tensioner and guide kit.
https://www.rockauto.com/en/moreinfo...t=5756&jsn=683
and getting sprockets from some Subaru parts website, along with all those rubber gaskets.
Old 07-01-2025, 09:07 PM   #527
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Not 100% sure on the exhaust but I know both intakes are different.
Old 07-05-2025, 04:25 PM   #528
Lantanafrs2
A yr ago I had to diag a chevy sedan of some sort that had an occasional misfire on decel and initial acceleration. Went through everything and found out through a source at gm that these motors (v6) would do this when cam chains were stretched. Changing sprockets/phasers wouldn't help. Never did the job as customer wasn't interested in spending the money, thankfully.
Old 07-10-2025, 12:09 PM   #529
kcratos
Drives: minimalist
So all sprockets are different and have different part numbers. Its so confusing bc parts from 2013 were discontinued and changed numbers.
Each sprocket is about 200 each.
I'm thinking to get just 1 sprocket since they are expensive.
the side with the code p0016 which is bottom passenger side. or "exhaust, right"
part number 13321AA032
I think this is the one.
plus the kit from rock auto with chains, guides and tensioners for about $250
plus some gaskets or seals i gatta find part numbers for, plus rtv.
so hopefully about $500 in parts.
what u guys think @tomm.brz
Old 07-17-2025, 11:38 PM   #530
tomm.brz
do it it doesnt hurt for sure
P0016 fixable without new ECU? Mr.Jay Issues | Warranty | Recalls / TSB 8 02-06-2022 06:15 AM
P0016/P0017 cause AVOturboworld Issues | Warranty | Recalls / TSB 18 04-17-2021 12:09 AM
P0016 Code Shady195 Engine, Exhaust, Transmission 30 02-21-2019 03:31 PM
p0016 need help asap lol Issues | Warranty | Recalls / TSB 25 10-30-2018 04:49 PM
OFT P0016 and TSB question mmmcambelsoup Software Tuning 10 05-24-2017 10:24 AM
