Old 06-11-2014, 09:43 PM   #1
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
P0016/P0017 cause
If you have a mechanical issue that is causing your car to stall out when coming to a stop [error codes P0016, P0017], it is likely because of your cam sprocket. This photo illustrates the issue - the little piece on the inside left that looks like it has a spring behind it is the cause. It is actually supposed to sit flush with the back, but it will pop out and cause a oil pressure loss, which causes the cam to not respond fully. If this has happened, the cam sprocket will need to be replaced unless you can get that piece to sit flush again.
Here is two more shots:
This is how the back of the cam sprocket should look - the piece is fit flush with the inner surface.
The entire sprocket/cam assembly.
AVOturboworld is offline   Reply With Quote
The Following 5 Users Say Thank You to AVOturboworld For This Useful Post:
blackfireball5 (06-15-2014), JB86'd (06-11-2014), JOSEC (06-12-2014), Lonewolf (06-15-2014), tyrantcf (06-12-2014)
Old 06-15-2014, 01:05 PM   #2
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
@AVOturboworld I am currently having a P0016 code that won't go away. Came back after I reflashed my ECU with my tune.
How hard of a job is this to inspect? Any links to diagrams to DIYs?
Also, I have an oil pressure gauge. Would you notice a dangerous or drastic drop in oil pressure when this happens?
Toyota has had my car twice. It is highly modified but they told me if this is something not caused by my mods they will cover it.
blackfireball5 is offline   Reply With Quote
Old 06-16-2014, 02:07 AM   #3
AVOturboworld
you can see it when logging with ecutek - the cams don't respond as fast as the other side. The graphs when revving up won't be similar to each other.
Old 06-16-2014, 02:14 AM   #4
blackfireball5
Awesome! This is great! I'll give this a shot tomorrow! Would you say it's dangerous to track the car with this issue?
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
Old 06-16-2014, 02:19 AM   #5
blackfireball5
What specific parameter do you log?
Wheelwell Profile
Old 06-18-2014, 08:05 AM   #6
DBW
Motorsports
Drives: 19BRZ PP, 16 M4
what keeps the metal piece sitting flush? is there a tab of some sorts?
Douglas W.
DBW is offline   Reply With Quote
The Following User Says Thank You to DBW For This Useful Post:
ATL BRZ (09-29-2018)
Old 05-02-2016, 06:49 PM   #7
PrDarkKnight
Director of Awesome!! :)
PrDarkKnight's Avatar
Drives: Scion FR-S
So the giveaway for this issue is the car turning off when stopped?
Life is all about the ride, so go full throttle baby!!
[SIGPIC][/SIGPIC]
PrDarkKnight is offline   Reply With Quote
Old 05-02-2016, 07:17 PM   #8
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Most like coincidental with codes P0016 and P0017
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
PrDarkKnight (05-23-2016)
Old 05-10-2016, 11:16 PM   #9
FR-Shred
FR-Shred's Avatar
P0017... No idling issues. Can be cleared while the car is on and doesn't come back up till you turn the car off and back on.
Any ideas?
Is this cam sprocket the only cause of the p0017 issue? I don't really want to spend $200 on a part and a day of labor to find out it's something else. Haha
FR-Shred is offline   Reply With Quote
Old 05-11-2016, 12:16 AM   #10
steve99
Any ideas?
check the TSB here
http://www.ft86club.com/forums/showthread.php?t=21868
might be a number of causes ecu/cam sprocket/sensor,ecu or sensor clearance
Old 07-05-2016, 12:29 PM   #11
EN2_Squirrel
EN2_Squirrel's Avatar
I just got the p0017 code this morning, could this be just the sensor? This came after having the p000b(exhaust cam position response slow) for a while. I cleared the code before I drove to work but it still was there according to my reader. I then just checked it at lunch right now and it didn't show at all. The part numbers for both are SU00300413 AND 414. Which one is for bank 1?
STREET MOD. My wallet now hates me....
EN2_Squirrel is offline   Reply With Quote
Old 07-15-2016, 08:53 PM   #12
osudoc11
Sorry to break the news, but typically this is the cam sprocket problem. Can you describe your issue a bit more? How does it idle?
osudoc11 is offline   Reply With Quote
Old 08-23-2016, 06:50 PM   #13
blackfireball5
Is there a guide on how to do this repair? Could someone detail at least how to access this to inspect?
Old 08-23-2016, 08:09 PM   #14
Ultramaroon
not playing cards
Ultramaroon's Avatar
This involves engine removal and valve train disassembly.
The rule here is "If I have to ask how, then I'm not qualified."
P0016 fixable without new ECU? Mr.Jay Issues | Warranty | Recalls / TSB 8 02-06-2022 06:15 AM
p0016 need help asap lol Issues | Warranty | Recalls / TSB 25 10-30-2018 04:49 PM
Major accident/Engine failure after repeated P0351/P0017/P0019 DB86 Issues | Warranty | Recalls / TSB 48 09-16-2014 04:05 PM
