Drives: 2017 86 MT BASE
Clunking noise at low RPMs in 1st & 2nd Gear?
Hey everyone, I've been hearing a sort of clunking noise when I drive in 1st & 2nd (no noise in 3rd-6th gear) at low rpms. Once the RPMs get high enough, the sound goes away, or if I've been driving the car for a while, like an hour or so, the sound also goes away even at low RPMs.
I brought it to the dealership and they inspected the entire under carriage but was not able to find anything making that noise. I am suspecting that it might be the clutch? or something with the transmission? My vehicle is a 2017 Toyota 86 base MT, with 33,500 miles on it. Any insight would be much appreciated, thank you in advanced! |
#2 | |
Drives: 2013 frs base
#4 |
I had a similar noise when I removed my Whiteline transmission insert and failed to keep the transmission mount's metal center post straight when retightening. This was a very one-off situation though.
What mods have you done in the transmission area? |
#5 |
I dont think i have any mods done around the transmission area. The only thing that was done under the car is an exhaust, front pipe, over pipe, an headers.
#6 | |
If possible, I'd try to mount a camera underneath the car to get a better sound sample of what's going on. I can hear the noise in your video but it's somewhat hard to make out. |
#7 |
I'll see if I can get a something to mount underneath the car while I'm driving, the car itself is pretty low already so that might be a no go. I'll definitely double check to make sure none of the pipes are hitting anything though, thank you!
| Problem with 1st gear and 2nd gear!?!? | Offwhite.86 | Engine, Exhaust, Transmission | 14 | 10-19-2020 11:37 PM |
| Clunky 1st gear and 2nd gear | Sleepyyysam | Issues | Warranty | Recalls / TSB | 14 | 05-23-2018 04:51 PM |
| No 1st gear or 2nd gear | sroby | Issues | Warranty | Recalls / TSB | 15 | 08-23-2016 07:40 PM |
| &&&&&&&&&&& | zpeed | Exterior Parts (Aero, Lighting, Etc.) | 3 | 02-07-2016 12:15 PM |
| No more 1st gear thump or 2nd gear notchiness | kc4mne | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 09-06-2012 08:39 PM |
