| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
Drives: 2013 Scion Frs
Rear Quarter Panel Crack
Hi, I bought my 2013 FRS knowing it had a small crack on the passenger side skirt. Long story short there was a spot on the interstate where there was a bump that caused the bottom of my car to slam on the road and it worsened from there. It looks like someone may have tried to do some sort of bondo repair on this spot before. I am considering my options of doing my own bondo job, taking it to a shop or potentially just throwing a body kit on it. Ideally I want to keep cost as low as possible but know that regardless it wont be cheap. If anyone has any ideas I am all ears. |
| The Following User Says Thank You to Sam_ For This Useful Post: | humfrz (04-24-2025) |
#2 |
Drives: 17 Asphalt 86
Looking at paint quality,(lack there of) the entire quarter panel has had body work done. A crack like that indicates there's a lot of bondo underneath which could be hiding something worse.
That panel needs to be taken down to bare metal to assess the damage. The bondo is failing and applying more won't fix the issue underneath. |
#3 |
It will buff out -
| The Following User Says Thank You to humfrz For This Useful Post: | JD001 (05-14-2025) |
#4 |
Drives: 2019 BRZ with Performance Package
#5 |
Drives: 2013 frs base
Is the car a "salvage"? I'd be worried that amount of body flex.
#6 |
#7 |
No that you know that car is garbage, you should throw it in the garbage.
#8 |
Famous Potatoes
Drives: '15 ultramarine
Call your insurance and see if they can help. It needs professional help. Maybe a quarter panel replacement.
#9 |
Drives: Toyota
Sam, since the damage appears to be worsened by a previous poor repair, a DIY Bondo fix could be a cost-effective short-term solution if you're comfortable with some sanding and painting.
#10 |
Drives: Subaru BRZ
| WTB Quarter Panel/ Rocker Panel/ Fender | mistergrafik | Want-To-Buy Requests | 3 | 11-15-2016 05:34 PM |
| Rear quarter panel replacement | sero901 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 09-25-2015 12:41 PM |
| Camber and spacers saved my rear quarter panel!!!! | suaveflooder | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 01-03-2014 12:37 AM |
| WTB FR-S RIGHT REAR QUARTER PANEL | Billylammerkins | Exterior Parts (Aero, Lighting, Etc.) | 7 | 01-01-2014 10:21 PM |
| Scratch + dent on rear quarter panel - fix or no? | rawbz | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 10 | 08-26-2012 11:50 AM |
