Old 04-24-2025, 08:27 AM   #1
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Serpentine Belt BS
My in-laws Subaru threw the serpentine belt and it got wrapped around the ac pump. Dealership it was towed to refuses to simply replace the belt and wants to replace all the pulleys and idlers. In-laws already confirmed all pulleys and idlers spin by hand, idler spring works, engine starts, and removed the belt and other debris themselves. Is there any way the dealer isn't full of it saying the extra work needs to be done?
Also: "Build Thread"
Spuds is online now   Reply With Quote
The Following User Says Thank You to Spuds For This Useful Post:
humfrz (04-24-2025)
Old 04-24-2025, 10:20 PM   #2
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
You have to discover why it threw the belt in the first place. Just because your in-laws can spin the pulleys and the spring has some tension doesn't mean there isn't a problem with one or more of them. How many miles on the car? Was all the services done per the book or only the basics when needed?
I'm not criticizing, just asking so you/they can make an informed determination. You replace all the spark plugs when you change them, not just a couple which look bad. Same goes for pulleys etc. especially if it’s a higher mileage vehicle.
Living life on the edge, less crowded, better view!
2018 tS Still in the family.
The Following 3 Users Say Thank You to Stephen W. For This Useful Post:
humfrz (04-24-2025), Spuds (04-24-2025), Teseo (05-04-2025)
Old 04-24-2025, 10:34 PM   #3
2.2Lude
2.2Lude's Avatar
I swapped out all of my idlers and tensioner when I did the S belt service. They all spun freely but two of the idlers hummed pretty loudly indicated bad bearings. The tensioner I just did preemptively as 80% + of the time the car only sees track use.
2.2Lude is offline   Reply With Quote
The Following User Says Thank You to 2.2Lude For This Useful Post:
Spuds (04-24-2025)
Old 04-24-2025, 10:50 PM   #4
Welp, they could just replace the belt, put it back together and see how it looks and sounds - maybe they will get lucky.
Spuds (04-24-2025)
Old 04-24-2025, 11:51 PM   #5
Spuds
The Dictater
Spuds's Avatar
Yeah it's got like 120k on it and my FIL can replace the pulleys himself. It probably went because the belt is 18 years old. Both of us understand there is more follow up to do.
The problem is the dealership refuses to just replace the belt and let him drive it home to do the rest of the work himself. They won't even explain why, other than "the technician said it has to be done".
Old 04-25-2025, 12:00 AM   #6
Spuds
The Dictater
Spuds's Avatar
Yes, but they also apparently want to swap out the crank pulley and maybe other stuff. Which sounds really weird.
Even if the idlers aren't in great shape, it should be fine to drive the 30 miles to his house.
humfrz (04-25-2025)
Old 04-25-2025, 12:37 AM   #7
Back in the day, when I had less money than I now do, I would have purchased a belt from the parts department, tell the dealer to give me the keys to my car, drove it off the lot, parked it on the street, replaced the belt and driven it home.
Spuds (04-25-2025), Stephen W. (04-25-2025)
Old 04-25-2025, 01:33 AM   #8
Spuds
The Dictater
Spuds's Avatar
That's basically what is happening as soon as the dealer gets the belt, which is apparently taking a week to get there.
humfrz (04-25-2025)
Old 04-25-2025, 12:21 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You are more polite than me. I would do it right in their parking lot. If they can’t tell me a reason something needs done they can pound sand.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
humfrz (04-25-2025), Teseo (05-04-2025)
Old 04-25-2025, 03:29 PM   #10
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I have never heard of a crank pully going bad.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
blsfrs (05-03-2025), humfrz (04-25-2025), Spuds (05-04-2025)
Old 04-25-2025, 07:57 PM   #11
But, if they do - they are a bitch to replace -
Old 04-25-2025, 08:03 PM   #12
Maybe go to the parts department in a bigger garage?
Spuds (05-04-2025), Stephen W. (04-25-2025)
Old 05-03-2025, 09:11 PM   #13
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I had the crank pulley on my son's 05 Forester go bad. The outer ring started slipping when the ac was on. It looked fine. I replaced the belt and was getting ready to replace the compressor when someone more knowledgeable than myself pointed out the problem.
The Following User Says Thank You to blsfrs For This Useful Post:
Spuds (05-04-2025)
Old 06-22-2025, 07:43 PM   #14
Lantanafrs2
Drives: 2013 frs red
I've replaced belts alone on good faith to save the customer money but as they say, no good deed goes unpunished. Nowadays I immediately specify tensioner and idler pulleys be replaced with the belt. Better to do the job once. Tows aren't cheap
Lantanafrs2 is offline   Reply With Quote
Serpentine belt driving me nuts Impureclient Issues | Warranty | Recalls / TSB 4 11-20-2020 02:00 AM
Serpentine belt coming apart BirdTRD Issues | Warranty | Recalls / TSB 35 12-27-2018 09:36 PM
Serpentine belt issue / So Cal LAX Airport russsak Issues | Warranty | Recalls / TSB 12 09-09-2018 05:11 PM
Serpentine Belt SlyCayer Engine, Exhaust, Transmission 3 04-13-2015 02:40 PM
Serpentine Belt Changeout Guide FRS BRZ Binbear4 DIY (Do-It-Yourself) Guides 0 11-17-2013 06:35 PM
