Old 12-22-2018, 11:57 AM   #1
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Serpentine belt coming apart
Ok, so I replaced my serpentine belt last month, <500 miles ago and it's doing the same thing. It's looks like it jumped a groove forward and tore the front edge of the belt apart.
The first belt was installed with the Edlebrock kit over 2 years and >20k miles ago with no issues. Now 2 belts in a month with the same front edge damage. All of the idler pulleys have a tiny bit of wiggle to them but I don't know what's an acceptable amount or if i should be looking elsewhere. (tensioner perhaps)
Any suggestions would be appreciated. (besides the obligatory "should've bought a ......) Thanks
BirdTRD is offline   Reply With Quote
Old 12-22-2018, 02:27 PM   #2
gtengr
Drives: 2017 BRZ
I would think it's either the tensioner or the bearing in one of the pulleys. How easy was it to move the tensioner when changing the belt?
gtengr is offline   Reply With Quote
The Following 2 Users Say Thank You to gtengr For This Useful Post:
BirdTRD (12-22-2018), Summerwolf (12-23-2018)
Old 12-22-2018, 02:52 PM   #3
Grady
Grady's Avatar
So the original belt with the SC lasted 20K? Now the 2 new belts go bad within 1 month. I would look at what has changed. First is obviously the belts. 2nd is the installation procedure. 3rd would be tensioner, then verifying pulley bearings/alignment.
The Following 2 Users Say Thank You to Grady For This Useful Post:
BirdTRD (12-22-2018), humfrz (12-22-2018)
Old 12-22-2018, 04:25 PM   #4
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
I would def think it would have to do with the tensioner perhaps wearing out, losing tension and then allowing the belt to have some
Slack causing it to jump a groove and cause it to get eaten up but I'm sure you have thought the same .
The idler pulley at the dealer is about 76 bucks (Subaru dealer in Modesto ca ). I would start with that since they are automatic tensioners.
Are you certain you have the right size belt ? I use gates belts for my jrsc and didn't change it up until recently after being on for about 3 years .
I may be wrong but let us know what you figure out
mswbrz is offline   Reply With Quote
The Following User Says Thank You to mswbrz For This Useful Post:
Old 12-22-2018, 04:35 PM   #5
BirdTRD
Simply Forgotus
BirdTRD's Avatar
I was under tension...how much exactly, I don't know, I used a 1/2 drive socket wrench with a piece of pipe on the end so I wasn't fighting it.
The original SC belt failed last month and I replaced it, now the new belt has failed, currently waiting for the second replacement belt, so the belt was only replaced due to failure with a Continental Elite Poly-V belt. Installation was done with just a wrench for the tensioner and my hands, no tools or prying on the belt.
I suppose if the tensioner has "weakened", that may allow for the belt to jump a rib and rip itself apart like it did, but I think I'm leaning more towards the idler bearings getting a little sloppy allowing the belt to walk. I just hate to throw parts at the problem but there's nothing super obvious at the moment.
Old 12-22-2018, 04:38 PM   #6
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Do you know if there is a spec on the tensioner tension and how to measure it?
Old 12-22-2018, 05:24 PM   #7
ls1ac
ls1ac's Avatar
I found on an earlier car that the make of the belt made a difference. Is the replacement the same manufacturer.
The Following User Says Thank You to ls1ac For This Useful Post:
BirdTRD (12-23-2018)
Old 12-22-2018, 08:13 PM   #8
Grady
Grady's Avatar
When bearings go out they can cause some harmonic vibrations that can make belts do weird things. I would feel each pulley, accessory drive when the belt is off to see if any of them have slack or sound weird.
BirdTRD (12-23-2018), humfrz (12-22-2018)
Old 12-22-2018, 08:50 PM   #9
Ultramaroon
not playing cards
Ultramaroon's Avatar
The belt will slacken upstream of the blower pulley for a moment when the engine sharply decelerates from a high rpm, like when dumping the clutch too early on an upshift. This is from the blower inertia continuing to yank on the tensioner after the crankshaft slows. Undamped tensioners are not good at countering this effect.
Have you changed anything in your driving style that might exacerbate that situation?
Old 12-22-2018, 09:35 PM   #10
humfrz
Yep, it sure does look like something is causing the belt to run a notch off center.
Is there a "right" and "wrong" way of installing the belt? I
If so, are you sure you put it on right?
I'd suggest that you move the belt over a notch (to center it), then have someone else start the car while you watch the belt to see if it moves sideways. If it stays in place at idle, rev up the engine and see it moves over.
humfrz
Old 12-22-2018, 11:07 PM   #11
mswbrz
mswbrz's Avatar
Since the tensioner is automatic their is no certain spec I'm aware of . I gave no idea on how to check the tension either bro :/
Old 12-23-2018, 08:18 AM   #12
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Honestly, I don't know what brand was sent with the Edlebrock kit, that was installed over 2 years ago and no issues up until a month ago.
I have switched to my left hand recently but what's that got to do wi.....oh wait, you said exacerbate....never mind. But no, nothing has changed in my driving style and no clutch to dump.
humfrz
I don't think the belt is directional....
For now, I cut all the "bad" parts off the belt so it's running with 4 ribs instead of 6. I don't see it trying to walk at idle so I'll need to get someone on the accelerator.
I checked on the new belt several times after I installed it and no problems.
I had just made a 180 mile trip the day before, it was cold and rainy so I actually took it easy, got home, no issues. Started the car the next morning to warm it up, sounded fine, about 10 minutes later I heard what I initially thought was large rain drops or small hail smacking the hood, but when I looked outside, it was just drizzling. That's when I realized it was the belt slapping the under side of the hood again.
I'm going to try to check pulley alignments today and make sure everything accessory and bracket wise, is secure.
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
humfrz (12-23-2018), Ultramaroon (12-23-2018)
Old 12-23-2018, 10:43 AM   #13
humfrz
[quote=BirdTRD;3166188]
Good plan to take the belt off and check all pulleys for play.
Please let us know what you find out.
Back-in-the-day, back-on-the farm, we learned real quick on how to eye ball the lining up of belts. About one slap up side the head with one of those long belts was all it took to learn that. With no "V" and no ribs and grooves, it didn't take much for a flat belt to slide off a pulley.
As a young boy, it was my job to sit on a stack of bags of grain and watch the belt and pulley. If I saw it creeping off, I was to wave my arms and someone would realign the tractor.
To ward off boredom, I would catch grasshoppers and set them on the belt just before one of the pulleys to see if they could jump off before they got squashed. -
humfrz
gravitylover (12-23-2018)
Old 12-23-2018, 11:03 AM   #14
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Weak tensioner
Pulley has come out of alignment
Always had good luck with "green stripe" belts in applications needing extra strength.
My guess in that order. Tensioner has extra work it's doing and you have now introduced non factory pulleys.
Serpentine belt issue / So Cal LAX Airport russsak Issues | Warranty | Recalls / TSB 12 09-09-2018 05:11 PM
Serpentine Belt SlyCayer Engine, Exhaust, Transmission 3 04-13-2015 02:40 PM
SOS. Monterey area. Belt tensioner/belt The Racers Line Northern California 11 04-06-2015 02:33 PM
Serpentine Belt Changeout Guide FRS BRZ Binbear4 DIY (Do-It-Yourself) Guides 0 11-17-2013 06:35 PM
