Old 04-04-2025, 10:52 PM   #15
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I ran -4/-2.2 camber, zero toe last year on 200TW (A052's) and I was amazed at how much the insides shredded with only ~4k street miles to and from events. 3 tires were showing cords and one was on a brink. All very even overall.
Still, I thought I'd at least make it a full season of autocross like that. Car drove fine though. No weird wandering issues people warned of.
cmiovino is offline   Reply With Quote
The Following User Says Thank You to cmiovino For This Useful Post:
2.2Lude (04-04-2025)
Old 04-04-2025, 11:19 PM   #16
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
I run -4.5/-3 with zero toe on mine but it doesn't get a ton of road miles and I didn't notice any unusual wear. I would definitely put mine more in the vein of "race car" than street car though.
RT-BRZ is offline   Reply With Quote
Old 04-04-2025, 11:26 PM   #17
2.2Lude
2.2Lude's Avatar
Curious, were you running an aftermarket front sway bar with your set up? I noticed tramlining on my set up once I put in a Eibach 25mm front bar.
2.2Lude is offline   Reply With Quote
Old 04-05-2025, 04:05 PM   #18
cmiovino
cmiovino's Avatar
I have a 19mm Perrin set on stiff which is only 75% stiffer than stock.
Old 04-10-2025, 01:39 PM   #19
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ
For the 2nd gen, I think you may have issues with this setup due to offset. The dang tab on the quarter panel. This is a great setup for 1st gen.
Stonehorsw is offline   Reply With Quote
Alignment settings/Alignment Shop v1beeee CANADA 27 04-24-2017 04:54 PM
WGP?CXR LS Kit (need feedback) Eris-time Engine Swaps 15 01-26-2017 12:20 PM
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 03:44 AM
ABS feedback?? calidus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-17-2015 06:39 PM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
