Old 03-24-2025, 03:31 PM   #1
leb_crx
Drives: 2023 BRZ
Alignment feedback
I am doing the following wheel/alignment mods all at once and looking for feedback on alignment specs; I been getting mixed information and hoping to find a setup that'll be a balance between street and track (4 full days a year roughly). Any feedback is appreciated
Specs:
Front Camber -3
Rear Camber -2.5
Toe out front 1/16 to 1/8
Toe in rear 1/16
Mods:
-Enkei RPF1’s 17X9 +35 square set up
-Hankook Ventus RS-4 255/40/17
-H&R lowering springs (25mm drop)
-Verus engineering camber plates
-Whiteline rear ajustable LCA
-Rear fender tab cut
-Arp extended wheel studs
Also, can anyone confirm if the rear toe is adjustable from factory?
leb_crx is offline   Reply With Quote
Old 03-24-2025, 04:29 PM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
That's a good setup. Rear toe is adjustable.
Front camber may be a touch on aggressive end for street, but really depends how often you use the car.
Old 03-24-2025, 06:55 PM   #3
Racecomp Engineering
Agreed. I'd probably go for 0 toe in front though.
- Andrew
Old 03-24-2025, 07:06 PM   #4
Tokay444
Anti stance.
Tokay444's Avatar
Always the same track?
Tokay444 is online now   Reply With Quote
Old 03-24-2025, 07:13 PM   #5
Ohio Enthusiast
Drives: 2018 BRZ
I run almost the same specs, a bit less toe out front and a bit more toe in rear. I dialed down the front camber to -2.8 as I was starting to get some uneven wear with -3.
I too find slight toe out to be nicer on the street. Can't say I feel twitchiness with toe out in the front, but I had a short stint of toe out in the rear (doing some suspension work and drove a bit before aligning the car) and that was pretty sketchy, especially on bumps.
For rear toe, it is adjustable from the factory, but it's horrible to adjust. I finally dialed in my alignment in the rear, but if I do any more suspension work I'll be getting aftermarket toe arms with easier adjustability.
Ohio Enthusiast is offline   Reply With Quote
Old 03-24-2025, 09:32 PM   #6
leb_crx
Drives: 2023 BRZ
Thanks for the feedback everyone. I am debating dialing back the front camber a bit for the first year (can always add more later in the year/next year)
Yes always the same local track (Calabogie) for now.
I realized I forgot to mention it, but it's a 23 BRZ.
Old 03-24-2025, 10:52 PM   #7
A little bit less front camber is probably a good idea if it's a daily driver that does a lot of daily driving. That said, I run about -3 and it's probably too much but it sure is fun.
- Andrew
Old 03-25-2025, 01:38 PM   #8
2.2Lude
2.2Lude's Avatar
I run -2.8 camber up front on 17x9 +35 ARC8's with 225/45 RT615k+'s and just clear my TRD springs. I honestly don't believe I could clear 245's right now let alone 255's with spacers. Your H&R's are probably about the same OD as the TRD, and most common lowering springs. Pedders top hats, SPC lower camber bolt with the OEM lower bolt in the top hole, and 0 front toe for reference.
-2.8 on the street was fine, no tram-lining or weird pulling until I installed the Eibach front bar. Now the set up will track with the road moderately but turn-in is much improved on the track.
2.2Lude is offline   Reply With Quote
Old 03-25-2025, 05:49 PM   #9
RToyo86
RToyo86's Avatar
I just had my alignment and corner balance done by Jeff at bag Babit(would recommend) and went
-2.5° front
-2° Rear
Toe 1mm out front(asked for 0..)
0 toe rear
Old 03-25-2025, 07:04 PM   #10
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Even with -4 front camber it drives totally normal on the street and that includes really bad irish roads and normal highway driving lol
I would go 0 front toe as well
autoracer86 is offline   Reply With Quote
Old 03-28-2025, 01:49 PM   #11
leb_crx
Drives: 2023 BRZ
Thanks everyone, really appreciate the input
going to Getty automotive for the alignment - whats bag Babit?
Old 03-28-2025, 02:26 PM   #12
RToyo86
RToyo86's Avatar
If you can get into Getty go for it
That was a typo I meant to say bad habit. Jeff Steinbakker runs a race shop for these and has done a few alignments for me so far. Worth checking the ft86 club of Ottawa, can find out discord as well.
Old 03-30-2025, 08:56 PM   #13
leb_crx
Drives: 2023 BRZ
Ah cool, I'll check them out, thanks!
Old 04-04-2025, 07:42 AM   #14
ZDan
ZDan's Avatar
Drives: '23 BRZ
-3 is no prob at all on the street.
I run zero toe front and rear rather than front toe-out front and rear toe-in. Anyway, I'd never go more than 1/16" toe either way, at either end.
Alignment settings/Alignment Shop v1beeee CANADA 27 04-24-2017 04:54 PM
WGP?CXR LS Kit (need feedback) Eris-time Engine Swaps 15 01-26-2017 12:20 PM
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 03:44 AM
ABS feedback?? calidus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-17-2015 06:39 PM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
