Old 06-23-2022, 02:51 AM   #281
gpvecchi
gpvecchi's Avatar
Yes, and the catbacks is separated from the front pipe by a joint that allows a little movement.
Old 06-23-2022, 12:52 PM   #282
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
How big of a hassle are the engine mounts to swap? I get a little contact between the OP and the subframe as well (only when accelerating hard and turning left, oddly). It'd be nice to eliminate that if possible, before I crack something.
Cephas is offline   Reply With Quote
Old 06-24-2022, 02:16 AM   #283
gpvecchi
gpvecchi's Avatar
Quite easy, you just need to jack up the car, support the engine and replace them one by one.
The Following User Says Thank You to gpvecchi For This Useful Post:
Cephas (06-29-2022)
Old 10-10-2022, 06:36 PM   #284
alexmak
Drives: 2014 Scion FR-S
I was trying to find the exhaust hanger at local Subaru dealerships in the US and I found this part # 44066AJ000. It has a very similar design, I wonder if it would have a similar effect. Might be an alternative to ordering parts from Japan or Europe.
alexmak is offline   Reply With Quote
The Following User Says Thank You to alexmak For This Useful Post:
Mil_Gates (02-17-2023)
Old 05-05-2024, 03:54 PM   #285
biggie
Drives: gt86
Originally Posted by worldwidewait View Post
I noticed that the front pipe is bolted to the chassis unlike the rear muffler. Has anyone retrofitted a rubber hanger here as well?
Did anyone tried to use some rubber washer between the L-bracket and the mouting point? I'm thinking, maybe, this will transmit less vibration to the chassis.
biggie is offline   Reply With Quote
Old 07-21-2024, 09:04 PM   #286
mrderp
ಠ_ಠ
mrderp's Avatar
Drives: 860 SansOverspray
4 years or so later, I got off my ass and did 4 of the 5 mounts.
I wish I found the screenshots of the before waveform. The difference is pretty incredible. The booming drone at 3000rpm is all but gone and the rattles around 2000 rpm are more manageable. Time will tell but I’m pleasantly surprised.
Usdm trd exhaust from day one on a 2017.
mrderp is offline   Reply With Quote
Old 07-22-2024, 06:18 PM   #287
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Hi everyone,
Quick question!
Is the distance between holes less in the sti vs the stock! Not sure if we can use them on the 2022+ models but would like to test them on the GR performance exhaust. It might help to raise the low tips just a little .
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 03-17-2025, 05:54 PM   #288
sneaky_pete
Drives: MY14 86 GTS Manual Velocity Orange
just tried to order this genuine Subaru part (44066AJ010) from Amayama and have been advised that there is a new part number: 44066AJ011
I have got 5 of them on the way for AUD$72.05 including freight from Japan.
sneaky_pete is offline   Reply With Quote
The Following User Says Thank You to sneaky_pete For This Useful Post:
Busybee (04-21-2025)
Old 03-18-2025, 03:20 PM   #289
Busybee
Busybee's Avatar
Yes! I got them from Blackhawk but was not able to get them installed. Weather is too cold.
Curious to see if it improves the little drone and the exhaust height. Was $25 for all five. Did not increase the shipping since I had other items ordered.
Old 04-21-2025, 02:03 AM   #290
sneaky_pete
I fitted mine today using the new part number 44066AJ011 and can confirm that this does work as intended. It makes a noticeable difference to the in car drone. very happy with this mod.
Old 04-21-2025, 02:08 AM   #291
Busybee
Busybee's Avatar
That’s great to hear! Finished all of my other installs and will focus on this. Did you install all 5 at once or did you test the rear ones first?
Thanks
Old 04-23-2025, 02:55 PM   #292
Busybee
Busybee's Avatar
Finally, did the install and also confirm that it made a dramatic difference on the GR performance exhaust! Wish did it before .
Old 05-22-2025, 02:28 AM   #293
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Did you install all 5 hangers or just the 2 near bumper ? I just did 2 in the back end and I think that it helped a little bit with my Fujitsubo A-R so now I'm wondering if changing the rest of them might help even more.
MrSkubi is offline   Reply With Quote
The Following User Says Thank You to MrSkubi For This Useful Post:
Busybee (05-23-2025)
Old 05-22-2025, 10:41 AM   #294
StraightOuttaCanadaEh
Wes
I did all 5 FWIW
Instagram: @gt86ws
Ecutek discovery solidsnake11 Software Tuning 7 08-25-2020 07:38 AM
Submitting For EDC Discovery Project quiksiv Off-Topic Lounge [WARNING: NO POLITICS] 16 04-26-2016 10:58 AM
ROM Table Discovery & Definitions Kodename47 Software Tuning 21 01-28-2016 03:30 PM
Oil? Strange discovery under glove compartment Seungify Issues | Warranty | Recalls / TSB 11 10-21-2013 06:58 PM
Front Suspension 'discovery'? Dimman BRZ First-Gen (2012+) — General Topics 13 07-23-2011 08:22 PM
