Old 08-23-2020, 01:00 PM   #1
solidsnake11
Drives: brz
Ecutek discovery
C
solidsnake11 is offline   Reply With Quote
The Following User Says Thank You to solidsnake11 For This Useful Post:
DarkPira7e (08-23-2020)
Old 08-23-2020, 01:35 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
So do you think it's possible to manipulate this table to increase starting reliability in the cold? I imagine if you set it to 1500rpm it'd be a long crank, and then successful turn over, rather than the typical Subaru 4 crank lazy start
The Following User Says Thank You to DarkPira7e For This Useful Post:
solidsnake11 (08-23-2020)
Old 08-23-2020, 01:39 PM   #3
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Pretty sure it doesn't work like that. It's likely part of the logic for the ECU to know that the car is started.
dragoontwo is offline   Reply With Quote
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
DarkPira7e (08-23-2020), solidsnake11 (08-23-2020)
Old 08-23-2020, 02:03 PM   #4
DarkPira7e
DarkPira7e's Avatar
That would make sense too!
Old 08-23-2020, 02:08 PM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
My car's startup is set at 1000rpm. I've not experienced any issues with it during winter but our winters aren't that cold.
The Following User Says Thank You to JD001 For This Useful Post:
Old 08-23-2020, 02:36 PM   #6
DarkPira7e
DarkPira7e's Avatar
With stock oil weight and a new battery, starting at -20f is slowgoing, but it happens. I was just interpreting this as a way to coax more effort out of the starter cycle, but it seems I was wrong
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
JD001 (08-23-2020), solidsnake11 (08-23-2020)
Old 08-23-2020, 06:49 PM   #7
dragoontwo
dragoontwo's Avatar
It would be nice if it worked like that, but I'm not sure the starter can even hit 1000 rpms alone. I would imagine if you set it higher you might end up overdriving the starter.
Old 08-25-2020, 07:38 AM   #8
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by solidsnake11 View Post
I changed it to 2000 then 3000. I don't think its starter rpm. I think its a timer of some sort. It didn't seem to change the port inj spike either.
I have it set to 1500 right now it seems to help my cold start stall but my car is far from stock.
I agree that this seems to be a timer of some sort, a pulse width.
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
solidsnake11 (08-25-2020)
Submitting For EDC Discovery Project quiksiv Off-Topic Lounge [WARNING: NO POLITICS] 16 04-26-2016 10:58 AM
ROM Table Discovery & Definitions Kodename47 Software Tuning 21 01-28-2016 03:30 PM
Oil? Strange discovery under glove compartment Seungify Issues | Warranty | Recalls / TSB 11 10-21-2013 06:58 PM
Discovery SCION FRS in Recent 86 Video Review. Zaku Scion FR-S / Toyota 86 GT86 General Forum 35 11-28-2011 02:41 PM
Front Suspension 'discovery'? Dimman BRZ First-Gen (2012+) — General Topics 13 07-23-2011 08:22 PM
