#155 |
Mebmer
Drives: Sienna, GR86, TourX
So the conclusion regarding the very knock-like sound when blipping the throttle from idle (stock at least) is that it’s normal and typical? Even if it’s actual knock?
I’m honestly a little disappointed with the engines non-responsiveness to quick throttle input. And that’s compared to FA20DIT and especially G16, which is also D4S and heavily turbocharged. This FA24 actually complains about it. It doesn’t sound like that’s something a tune can solve? |
#156 |
Drives: brz 2017 hksv2
it s not actual knock and yes it s normal whel idle rpm are kept so low like on stock tune and some oft tunes
every other tune raise idle at least to 750 a tune will mostly solve it |
| The Following User Says Thank You to tomm.brz For This Useful Post: | Clipdat (04-16-2023) |
#157 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
If you hammer something hard enough,
it'll sound like it got hammered?
"I gotta rock." -- Charley Brown |
#158 | |
Proud of BOXER
Drives: Subaru Boxer
| The Following 2 Users Say Thank You to Clipdat For This Useful Post: | bcj (04-16-2023), Ultramaroon (04-17-2023) |
#159 |
Drives: 2024 GR86
Has anyone here found a fix for this issue of the clank during throttle blip? It's super annoying and happens during rev matching also.
Clearly audible at 2, 8, 14 and 24 seconds. Not the pump noise that starts at 22 seconds. https://m.youtube.com/shorts/7lsxgv2qcQ0 Last edited by Fishbone; 07-01-2024 at 02:34 PM. |
| The Following User Says Thank You to Fishbone For This Useful Post: | Clipdat (08-19-2024) |
#160 | |
Drives: 2013 frs base
#162 |
Drives: 2022 Subaru BRZ Limited 6MT
I have a 2022 BRZ 6MT w 17K miles, I've also noticed this happening in the last 3K. If I'm in neutral coasting, say to go over a speed bump then I stab the accel pedal to rev match I've heard what sounds like a single engine knock - and when it happens I always try coasting and trying to get it to happan again and I can't. It seems intermittent, very frustrating. I'm getting towards the end of regular warranty and also have a squeaky clutch pedal when releasing, ugh.
#163 | |
Drives: 2024 GR86
#164 | |
Drives: 2024 GR86
https://youtube.com/shorts/TRFNSn5UK8Q?feature=share |
#165 | |
Proud of BOXER
That does sound somewhat similar, but also slightly different. I assume this only happens with the AC is on/running?
#166 |
Drives: 2024 GR86
| Rough idle leads to stall, runs well under load, no engine response on throttle blip | gensch | Issues | Warranty | Recalls / TSB | 8 | 09-01-2021 08:26 AM |
| Abnormal noise when throttle blip or WOT shifting | evo4g63 | Issues | Warranty | Recalls / TSB | 48 | 10-16-2014 08:42 AM |
| Throttle Blip Hiss | Wepeel | Issues | Warranty | Recalls / TSB | 29 | 05-30-2014 11:56 PM |
| Metal Grind Sound when throttle blip | JDM-dono | Issues | Warranty | Recalls / TSB | 0 | 11-17-2013 04:37 AM |
| Throttle Blip, and other features? | ashtray | BRZ First-Gen (2012+) — General Topics | 39 | 03-07-2012 10:52 AM |
