Old 04-14-2023, 05:26 AM   #155
fredzy
Mebmer
fredzy's Avatar
Drives: Sienna, GR86, TourX
So the conclusion regarding the very knock-like sound when blipping the throttle from idle (stock at least) is that it’s normal and typical? Even if it’s actual knock?
I’m honestly a little disappointed with the engines non-responsiveness to quick throttle input. And that’s compared to FA20DIT and especially G16, which is also D4S and heavily turbocharged. This FA24 actually complains about it. It doesn’t sound like that’s something a tune can solve?
fredzy is offline   Reply With Quote
Old 04-14-2023, 06:52 AM   #156
tomm.brz
Drives: brz 2017 hksv2
it s not actual knock and yes it s normal whel idle rpm are kept so low like on stock tune and some oft tunes
every other tune raise idle at least to 750
a tune will mostly solve it
Clipdat (04-16-2023)
Old 04-14-2023, 10:58 AM   #157
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
If you hammer something hard enough,
it'll sound like it got hammered?
Old 04-16-2023, 04:04 AM   #158
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
bcj (04-16-2023), Ultramaroon (04-17-2023)
Old 06-28-2024, 11:46 AM   #159
Fishbone
Drives: 2024 GR86
Has anyone here found a fix for this issue of the clank during throttle blip? It's super annoying and happens during rev matching also.
Clearly audible at 2, 8, 14 and 24 seconds.
Not the pump noise that starts at 22 seconds.
https://m.youtube.com/shorts/7lsxgv2qcQ0
Fishbone is offline   Reply With Quote
The Following User Says Thank You to Fishbone For This Useful Post:
Clipdat (08-19-2024)
Old 06-30-2024, 02:21 PM   #160
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Originally Posted by Fishbone View Post
Has anyone here found a fix for this issue of the clank during throttle blip? It's super annoying and happens during rev matching.
https://youtube.com/shorts/LNJtodrqDK0?feature=share
Video won't play.
Old 06-30-2024, 09:29 PM   #161
Fishbone
Drives: 2024 GR86
Fixed the video
blsfrs (07-01-2024)
Old 07-21-2024, 02:48 AM   #162
diga
Drives: 2022 Subaru BRZ Limited 6MT
I have a 2022 BRZ 6MT w 17K miles, I've also noticed this happening in the last 3K. If I'm in neutral coasting, say to go over a speed bump then I stab the accel pedal to rev match I've heard what sounds like a single engine knock - and when it happens I always try coasting and trying to get it to happan again and I can't. It seems intermittent, very frustrating. I'm getting towards the end of regular warranty and also have a squeaky clutch pedal when releasing, ugh.
diga is offline   Reply With Quote
Old 07-26-2024, 09:42 AM   #163
Fishbone
Drives: 2024 GR86
You have to let the revs fall all the way down to idle or when the revs are falling fast from say a rev match. You should be able to duplicate it at a standstill and not moving.
Old 07-26-2024, 10:17 AM   #164
Fishbone
Drives: 2024 GR86
I hear you, it feels like you're doing something bad. I replicated it again today after driving home and was able to do so with both clutch depressed and up, didn't seem to matter.
It doesn't do it every time, but it's fairly easy to replicate. Interesting how if the revs are above the ~600rpm resting idle it doesn't do it whatsoever. So if you just feather the throttle slightly and then stab it, it revs normally and sounds fine/healthy. It only hiccups/clunks/knocks or whatever when you "surprise" it with a throttle stab when it's at rest.
I checked the DI computer bolts and all three were snug. I'll have to do some datalogging with the OFT as well and see if this is a knock event. At least if it is we'll know if it's something gasoline/fueling related.
I've isolated the noise on my 2024 GR86 6spd to the AC compressor clutch disengaging and reengaging during the throttle blips. Can you confirm you have the same noise. I've gone to my dealer and they are ordering a new AC compressor under warranty. In the long run, I can see premature wear of the AC clutch due to this.
https://youtube.com/shorts/TRFNSn5UK8Q?feature=share
Old 08-19-2024, 07:12 PM   #165
Clipdat
Proud of BOXER
Clipdat's Avatar
That does sound somewhat similar, but also slightly different. I assume this only happens with the AC is on/running?
I'm old and lazy
Old 09-04-2024, 10:44 AM   #166
Fishbone
Drives: 2024 GR86
I've confirmed that this happens with regardless if the AC is on or off.
Rough idle leads to stall, runs well under load, no engine response on throttle blip gensch Issues | Warranty | Recalls / TSB 8 09-01-2021 08:26 AM
Abnormal noise when throttle blip or WOT shifting evo4g63 Issues | Warranty | Recalls / TSB 48 10-16-2014 08:42 AM
Throttle Blip Hiss Wepeel Issues | Warranty | Recalls / TSB 29 05-30-2014 11:56 PM
Metal Grind Sound when throttle blip JDM-dono Issues | Warranty | Recalls / TSB 0 11-17-2013 04:37 AM
Throttle Blip, and other features? ashtray BRZ First-Gen (2012+) — General Topics 39 03-07-2012 10:52 AM
