Old 05-28-2014, 11:28 PM   #1
Wepeel
Drives: '13 BRZ Ltd
Throttle Blip Hiss
So lately I've been noticing a quick hissing noise during throttle blip - first started noticing it when blipping for downshifts, but can induce it blipping the throttle from idle. I've seen the other threads that talk about a knock or pop during blip, and I definitely do not have that. It happens at a rapid blip of the throttle and just sounds like a very quick hiss, almost like you can hear the air induction. Noise won't happen in other kinds of driving, rolling on throttle, WOT, etc. No other odd noise otherwise.
Anybody else notice this?
Wepeel is offline   Reply With Quote
Old 05-29-2014, 01:02 AM   #2
humfrz
You may consider plugging up the sound generator tube at the firewall and see if you still hear the "hiss".
My 71 year old ears can't hear "hiss" and a lot of other sounds anymore ..... so, I don't know if my car hisses or not ..
humfrz
Old 05-29-2014, 02:09 AM   #3
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
It could be noise coming from the sound tube. Try covering it and replicating it.
N1rve
Old 05-29-2014, 02:26 AM   #4
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
humfrz
You're 71!?
ericmpena is offline   Reply With Quote
Old 05-29-2014, 03:51 AM   #5
N1rve
N1rve's Avatar
Originally Posted by ericmpena View Post
You're 71!?
And a veteran too I believe. One that can use a computer quite well.
N1rve
Old 05-29-2014, 03:52 AM   #6
gonzo
Drives: frs
humfrz
You're 71!?
Yes, that's what he said!?
gonzo is offline   Reply With Quote
Old 05-29-2014, 07:25 AM   #7
tjf
Drives: Toyota 86
Smile
You're 71!?
No. His ears are 71.
tjf is offline   Reply With Quote
Old 05-29-2014, 08:51 AM   #8
Wepeel
Drives: '13 BRZ Ltd
Haven't tried plugging the sound tube, but it's audible from outside of the car and with the windows down.
Old 05-29-2014, 10:43 AM   #9
humfrz
You're 71!?
Yep, if you saw me ....you'd believe it .....
humfrz
Old 05-29-2014, 11:03 AM   #10
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I hear the hiss too...pretty sure its normal
Old 05-29-2014, 11:12 AM   #11
humfrz
Yep, Viet Nam era veteran.
Well, I had a head start with home computers, when I purchased my first one back in '82 for $99.95.
It was called a Timex Sinclair 1000 ...... and it was a screamer .... Used a cassette recorder for data storage and a B&W TV for a monitor.
Anyone still with me .. ?? Anyone .. ??
OK, time to go eat my oatmeal .....
humfrz
Old 05-29-2014, 11:35 AM   #12
Mr 286
Mr 286's Avatar
Drives: 2014 Camry SE V6 | 1991 MR2 Turbo
The hiss is definitely not normal. I had a similar sound occur about a month or two before the pilot bearing went out on my clutch (something I was told by a mechanic is quite common on Subarus). So, if you're hearing a sound like you've got a vacuum leak or hiss when you blip the throttle, it may be a sign that the clutch pilot bearing is about to go soon. Hissing will go away and come back intermittently. Then there will be a rattle when it does go.
Keep an eye on this and don't just write it off as normal noise. If it isn't something you expect to hear, then it is never normal noise. Hopefully yours is not as severe an issue.
Mr 286 is offline   Reply With Quote
Old 05-29-2014, 12:26 PM   #13
strat61caster
strat61caster's Avatar
I hear a clicking that's rather mechanical, I've always attributed it to the electronic throttle quickly snapping open the throttle valve when I stab the gas.
ineedyourdiddly
Old 05-29-2014, 12:29 PM   #14
ZionsWrath
Thanks
ZionsWrath's Avatar
Video? I don't hear any "hiss". But my quiet may be your hiss, who knows...
Hum/hiss when audio off? (BRZ) MysteryMachine Electronics | Audio | NAV | Infotainment 9 12-13-2014 07:58 AM
Abnormal noise when throttle blip or WOT shifting evo4g63 Issues | Warranty | Recalls / TSB 48 10-16-2014 08:42 AM
Metal Grind Sound when throttle blip JDM-dono Issues | Warranty | Recalls / TSB 0 11-17-2013 04:37 AM
"blipping" the throttle takes more that a blip?! KSC BRZ First-Gen (2012+) — General Topics 49 02-27-2013 07:04 AM
Throttle Blip, and other features? ashtray BRZ First-Gen (2012+) — General Topics 39 03-07-2012 10:52 AM
