Old 07-18-2024, 12:20 AM   #1
frenchfriesguy
Drives: 2023 Toyota GR86 PMT (Neptune Blue)
CSG Brembo BM-4 BBK torque values?
I recently acquired a second hand set of CSG Brembo BM4 BBK and was wondering what the torque values were for the bracket but also caliper to bracket
frenchfriesguy is offline   Reply With Quote
Old 07-18-2024, 02:17 PM   #2
jflogerzi
jflogerzi's Avatar
best to reach out to them directly.
2013 Series 10 FRS #553
Old 07-18-2024, 09:20 PM   #3
frenchfriesguy
I did and they responded!
Hello,
Thank you for reaching out to us.
Installing the CSG Brembo BM4 on your 2023 Toyota GR86 involves several key steps to ensure proper fit and function. First, secure the car by lifting it and removing the wheels. Clean all brake components thoroughly. Remove the existing brake caliper and bracket, along with the old brake pads and rotor.
Position the new guiding bracket (caliper bracket) and secure it to the wheel hub with the provided bolts, tightening them to 85-90 Nm (63-66 ft-lbs). Install the new rotor onto the hub and ensure it is properly seated. Next, position the new caliper over the rotor and guiding bracket, securing it with bolts torqued to 28-32 Nm (21-24 ft-lbs). Insert the new brake pads into the caliper, ensuring they are correctly seated. Connect the brake lines to the new caliper, tightening the banjo bolt to 20-25 Nm (15-18 ft-lbs), and bleed the brakes to remove any air from the system.
Finally, reinstall the wheels and lower the car. Double-check all bolts for proper torque, ensure brake fluid levels are adequate, and perform a test drive to confirm that the brakes are functioning correctly.
If you are new to DIY car repairs, we recommend reaching out to a mechanic or dealership to ensure there are no issues after installation and to ensure all parts are correctly fitted and functioning safely.
Appreciate your understanding.
Thank you for choosing BrembostoreUSA.com!
Old 07-18-2024, 10:24 PM   #4
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
The caliper to bracket torque seems too low; these seem more aligned with the conventional sliding calipers.
My Brembo GT kit, bracket bolts are torqued up to 115 Nm
For your safety, I recommend getting a second reference/opinion.
Again, below are instructions for the GT kit, but I presume the BM4 is very similar as far as structural requirements and integration.
EndlessAzure is offline   Reply With Quote
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
RedReplicant (07-19-2024), ruturaj001 (07-19-2024)
Old 04-18-2025, 08:46 PM   #5
darthwong1138
Drives: Raven FR-S
What did you end up torquing the bracket to knuckle bolts to? The Brembo instructions state to toque to factory spec which for a 2016 FR-S is 59 ft lbs. But the factory bolts have a finer thread and a lock washer. 59 ft lbs seems a little on the low side for the hardware provided by the Brembo kit.
darthwong1138 is offline   Reply With Quote
Old 04-21-2025, 03:22 AM   #6
EndlessAzure
Wheels for Brains
What step/diagram?
  • Step/Diagram K - Use OEM (80 N-m/59 ft-lb)
    • Brembo BBK doesn't react appreciably more or less torque than OEM brakes, so the spec to the knuckle isn't any different.
  • Step/Diagram N - Use Brembo (115 N-m/85 ft-lb)
    • Factory brakes carry the load in shear through the caliper slide pins. Brembo BBK doesn't use slide pins, so it carries the load through the bracket hardware.
DIY: 86 Tightening Torque Values zeal86 DIY (Do-It-Yourself) Guides 55 06-20-2023 01:42 PM
Project Mu 999 pads for Brembo brakes or brembo BBK. Still sealed in the box. $200 Jstyle Brakes, Suspension, Chassis 3 06-13-2022 01:23 PM
Oem Brembo Front/Rear caliper mount torque spec sroby Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-24-2020 06:23 AM
Brembo Torque Specifications mkodama Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 10-03-2019 04:41 PM
Values in "Requested Torque B" Tor Software Tuning 3 07-29-2016 05:02 AM
