Old 06-12-2018, 04:01 AM   #1
mkodama
86 Challenge
Drives: 2017 BRZ
Brembo Torque Specifications
What’s the specified torque for caliper mounting bolts on the Performance Package Brembo calipers, and are the caliper bolts reusable?
Unofficial answer:
59lb-ft/80Nm with anti-seize has been working great; numerous track days with no issue, and taking the calipers off a year later everything looked great.
mkodama is offline   Reply With Quote
Old 06-12-2018, 06:56 PM   #2
Grady
Grady's Avatar
Brembo’s use German torque. Gutentight, I beleive is the setting.
Old 06-12-2018, 07:15 PM   #3
FirstWinter
Drives: Car
Yes, they're reusable. Are these the fronts? If so, 60 ft-lbs and call it a day.
FirstWinter is offline   Reply With Quote
Old 06-13-2018, 01:01 AM   #4
mkodama
86 Challenge
Drives: 2017 BRZ
lulz
This is what I ended up going with. Dry, it is impossible to properly torque these bolts with less than 120Nm as they want to seize. With some copper anti-seize, all 4 front bolts tightened to their original position(clocked with a pen mark) at 60ft-lb/80Nm.
Old 06-28-2018, 10:43 PM   #5
Razorlor
Drives: 2017 BRZ Limited, Perf Package
I looked in my service info, I don't have any specs listed for either. Should just be able to snug em both up and be fine, add a little extra oomph to the banjo bolts.
Razorlor is offline   Reply With Quote
Old 07-31-2019, 06:46 AM   #6
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Stumbled upon this thread, as well as a similar thread on an STI forum.
https://forums.nasioc.com/forums/sho....php?t=2894993
Looks like the answer is ~80–88 lb-ft which with anti-seize translates to about 60 lb-ft indeed.
timurrrr is offline   Reply With Quote
Old 08-01-2019, 05:22 PM   #7
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
3 ugga duggas should do it!
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
Old 10-03-2019, 03:41 PM   #8
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Front caliper bolts: 88.5 ft·lb or 120 Nm
Rear caliper bolts: 53.8 ft·lb or 73 Nm
Bleeder valves: 14.8 ft·lb or 20 N·m
Source: Subaru BRZ, 2020 Service Manual
Compression Test Values - Factory Specifications? kharn83 Engine, Exhaust, Transmission 14 11-13-2017 02:21 AM
Requesting OEM Clutch Line Specifications RJasonKlein Engine, Exhaust, Transmission 6 05-21-2015 12:06 AM
TRD GT86/AERO Specifications 1904 Cosmetic Modification (Interior/Exterior/Lighting) 8 11-06-2014 02:03 AM
front and rear fender well specifications PineappleFriedRice Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-22-2013 06:06 PM
