| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
#15 |
Drives: 2018 BRZ
I never understood the point of posting a link to a YouTube video in an enthusiast forum and not giving any details about the video, especially if you are the creator of the video. It's such blatant click-baiting and trying to get views that I immediately don't want to give my views to that person. Combined with a very lengthy video that is mostly 3 dudes sitting on a couch talking, it's even worse. Want to garner my views by marketing your content in a forum? How about sharing some of that knowledge in the platform you're advertising on.
| The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post: | OkieSnuffBox (07-29-2024), Ultramaroon (07-23-2024) |
#16 | |
Drives: '22 BRZ Limited MT
#17 | |
Drives: Toyota GT86
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
| The Following 2 Users Say Thank You to autoracer86 For This Useful Post: | Frost (07-19-2024), ruturaj001 (07-19-2024) |
#18 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
That said, my hypothesis that has been confirmed in my data at CTMP GP is that autocross usually does NOT induce the longevity of lateral G loads enough to make this a concern. We specifically picked this track (CTMP GP) due to the insanely long right handers that occur at very high speeds to basically induce as long of a right hander as fast as possible. I know the US AutoX Nationals run MUCH bigger courses than I'm used to up here in Canada so I might be wrong in my narrow aspect of AutoX up here. I would still suggest to anyone that you overfill by at least 500mL if not 750mL to be safe and log oil pressures. It's so worth it. I still love the car - just now trying to help the community solve this issue especially with the second gen fixing so many of the original twin's problems. Happy driving.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
| The Following User Says Thank You to Frost For This Useful Post: | diga (07-28-2024) |
#19 | |
Thanks for taking the time to watch!
OTA LIVE TIMING LINK Last edited by Frost; 07-19-2024 at 10:06 AM. |
#20 | |
But we've even gone thru the painstaking process of making a thumbnail that's clickbaity BUT informative (full stock) and even added chapters. This is on top of the physical work of sourcing parts (using our own money), building the lower half of the engine (on our own time) and then putting my own car on the line. If you're going to give up on not even spending 60s to read the chapters and giving us a chance to recuperate some views for this work, then that's that I suppose. TLDR: - Confirmed gen2 twins will get close to starving at full stock. - Temp patch is to overfill by 500-750mL and maybe even 1L if you're ok with the effects. - Oil run is Motul X-Clean 5w30. Oil temps hit 130 deg C in 7 minutes of hard hard driving with ambient at 17-19 deg C air temp. - Conclusion: Car has two related problems; in priority they are 1. Oil pan is not sized for long high G right handers, 2. Oil temps run way too high with WOT driving.
OTA LIVE TIMING LINK Last edited by Frost; 07-19-2024 at 10:03 AM. |
| The Following 2 Users Say Thank You to Frost For This Useful Post: | new2subaru (07-23-2024), Ohio Enthusiast (07-19-2024) |
#21 | |
Drives: 2022 BRZ sport-tech
One thing i do not get though, if cup cars are not blowing up, why are weekend track guys/TA participants losing their motors?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#22 | |
| The Following User Says Thank You to Frost For This Useful Post: | Petah78 (07-19-2024) |
#23 | |
Drives: '22 BRZ
#24 | |
Having said that, i am not disagreeing with your findings. I am just wondering what is the minimal oil pressure threshold for the FA24? Is the low pressure observed within the design tolerance? Likely not....i just find it fascinating that cup cars survives while street driven tracked/TA guys does not.
#25 | |
| The Following User Says Thank You to jetvermillion For This Useful Post: | Frost (07-19-2024) |
#26 | |
... Or... we blow up an engine due to oil starvation on purpose (destructive testing). Our opinion of 29psi being low but not catastrophic is based on previous experience on engines but its not a 100% guarantee. I'm sending out my oil for analysis to truly see if we had issues from that video. Stay tuned. As for the Cup car guys running on slicks, yeah they probably might hit a peak G once or twice in their sessions but I'm not sure if they could sustain it like we can for OTA (we literally schedule runs such that you have 3 hot clean laps). Most of us run 200tw cheater tires which can be just as bad for lateral Gs. The key thing is that we don't want THE MOST G's ever, its just finding out what the threshold is to have starvation due to lateral G's. Clearly its already below what the PS4s can do (which I believe is > 1G) so basically... any sticky tire will only make it worse.
#27 |
Drives: Toyota GT86
900brz did a blog post about the cup cars and they are running 7.0L of oil so I think that helps A LOT
#28 | |
This is as quoted on the site: "Fill level Specified fill volume is 6.0 US quarts in the sump, with an additional 1.0 US quarts in the oil cooler circuit. So there is a total of 7.0 US quarts combined. The drain and fill procedure specifies leaving the oil in the oil cooler circuit, draining the sump, and refilling with 6.0 US quarts, which would equate to a 0.7 US quart overfill. NOTE: I was also told that the teams are only required to fill to the max level on the dipstick and the dipstick is unchanged from the street car, so this contradicts overfill specified in the service instructions. " That's 7 Quarts total or 6.624 liters with at least 1 Quart in the oil cooler or 0.946 L. They approximate roughly a 0.7 Quart overfill or roughly 0.662 L. Please don't mix up the units! The overfill amount works out to the same range I've been suggesting to anyone asking me on the topic (500 - 750mL).
| The Following 4 Users Say Thank You to Frost For This Useful Post: |
| Another FA24 swap | blsfrs | Engine Swaps | 40 | 12-21-2024 11:59 AM |
| FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 11:18 AM |
| Supercharged FA24 | knapper | Forced Induction | 11 | 12-16-2021 02:14 AM |
| Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 11:55 AM |
| FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 04:59 PM |
