Old 12-10-2021, 08:16 AM   #1
knapper
knapper's Avatar
Drives: '13 Scion FR-S - Whiteout
Supercharged FA24
Not sure if this has been posted, but I did a quick search for it and didn't find it.
Harrop's SC setup with FA24F:
Current: 2013 Scion FRS - Whiteout
knapper is offline   Reply With Quote
The Following 2 Users Say Thank You to knapper For This Useful Post:
Pete (12-10-2021), whataboutbob (12-10-2021)
Old 12-10-2021, 10:23 AM   #2
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
I get a little triggered everytime someone says the FA24 in the BRZ/GR86 is the Ascent motor... its technically not EXACTLY the same motor.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
The Following 2 Users Say Thank You to Frost For This Useful Post:
knapper (12-10-2021), NoHaveMSG (12-15-2021)
Old 12-10-2021, 11:42 AM   #3
Brz-123
100% agree. Not the same motor.
Ascent motor is lower compression ratio , only direct injected and turbo from factory , FA24F
The BRZ one is higher comp ratio and dual injected NA. FA24D
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
The Following User Says Thank You to Brz-123 For This Useful Post:
nikitopo (12-11-2021)
Old 12-10-2021, 12:00 PM   #4
knapper
knapper's Avatar
Agreed. He does clarify that it is the FA24F with lower compression though. I wonder how easy a swap would be, obviously being that it is already turbo from the factory, it is better suited for abuse.
Old 12-10-2021, 12:10 PM   #5
PulsarBeeerz
Drives: JRSC BRZ SOLD
The FA24F IS DI only buuut since our port injectors are in the IM assuming the FA20 IM ports line up with the block it doesn't matter. You would still end up with DI/PI that the FA20 ECU could handle just with a larger block. It can't possibly be as simple as swapping HW over from the FA20D to the FA24F right, right?
PulsarBeeerz is offline   Reply With Quote
Old 12-11-2021, 12:35 AM   #6
wheelspeed
Large Member
Drives: Ford Flex, ZX9R, FLHTCUi, DRZ400S
Looks heavy. How much weight does that thing add to the car?
- Have fun!
wheelspeed is offline   Reply With Quote
Old 12-11-2021, 01:17 AM   #7
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
This. Not the same motor. One is build with FI in mind , the other not.
Old 12-11-2021, 06:11 AM   #8
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Well people said the same thing of the WRX FA20 being an interesting swap into the 1st gen platform. 8-9 years later, no one's yet been able to make it run without a standalone ECU.
alex87f is offline   Reply With Quote
The Following 2 Users Say Thank You to alex87f For This Useful Post:
Brz-123 (12-11-2021), knapper (12-14-2021)
Old 12-15-2021, 03:27 PM   #9
Tatsu333
Drives: 2020 BRZ Sport Tech RS
In another thread (about a possible FA24D/FA20D hybrid block swap) where I asked about this (swapping an FA24F block instead), the response was:
Originally Posted by cactus View Post
Turbo motors had the starter mounted differently and the case half wont accept the BRZ starter with the stock trans.
So it doesn't appear that an FA24F block swap is simple. FA24D blocks are not yet available from Subaru, but even those could be problematic since their literature said something about changing the engine mount locations...
Tatsu333 is offline   Reply With Quote
Old 12-15-2021, 06:01 PM   #10
RedReplicant
Drives: None
Also notice that the alternator is mounted backwards
RedReplicant is offline   Reply With Quote
Old 12-16-2021, 01:13 AM   #11
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
This is custom for their time attack build and custom belt system. Looks like they have an Accusump style dry sump setup in the alternator spot and put the alternator reverse mounted down on the other side. The double pulleys are to run an eight cog pulley versus the standard six, and I think they are running a larger crank pulley to make more boost because they already maxes out how small they can make the supercharger pulley.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Brz-123 (12-16-2021)
Old 12-16-2021, 01:14 AM   #12
Irace86.2.0
60lbs I think. The extra 200hp can offset the weight fairly easy.
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 10:18 AM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 08:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 10:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 03:59 PM
c7 vs. supercharged 86 Hades FR-S / BRZ vs.... 101 12-14-2018 02:41 PM
