Old 07-15-2024, 06:40 AM   #1
mkootayy
Drives: 2013 subaru brz black
base timing idle in gear values
couldnt find info on if i needed to recode in the .xml file or maybe i could edit the table values to set a rpm scale higher than the original 2000rpm in Base timing idle in gear above speed threshold for of course a pop tune
attached is an after/before edits
mkootayy is offline   Reply With Quote
Old 07-18-2024, 01:21 AM   #2
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Yes it's fine to rescale the axis,s works fine as long as values are ascending in axis
AussieBRZ is offline   Reply With Quote
Timing Gear clicking? Maverick28 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 07-05-2021 11:43 PM
High Idle (up to 3k) while stopped in gear Eazy-V Software Tuning 23 01-24-2020 10:37 PM
base timing A gt7877 Software Tuning 5 11-08-2019 09:19 AM
Base Timing A vs Base Timing B NoHaveMSG Software Tuning 2 01-08-2018 04:31 PM
Intake Cam Timing advanced 20 Degrees at IDLE Kris86 Engine, Exhaust, Transmission 67 08-25-2017 04:28 PM
