Old 01-08-2018, 01:34 PM   #1
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Base Timing A vs Base Timing B
I have searched the "google" far and wide for an answer on the difference between these. The only definition that I could find was an old Nasioc post saying one is cruse and one is non cruise.
I am assuming A is closed loop timing, and b is open loop then?
Old 01-08-2018, 03:21 PM   #2
Tor
Tor's Avatar
Drives: Toyota GT86
No. Base Timing A is active if your AVCS is not working. I assume it's using this table in limp mode too, but not sure. Never saw limp mode, but Base Timing A is active every time after a cold flash until your AVCS activates.
Tor is offline   Reply With Quote
Old 01-08-2018, 03:31 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Ahh. I guess that makes more sense then being active based on injection mode. Thanks!
Cam timing on Dyno aruxe Software Tuning 74 06-11-2019 03:32 PM
Engine timing? MJferg Engine, Exhaust, Transmission 3 05-13-2017 07:38 AM
Don't know how to set timing. MJferg Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 12-27-2016 09:36 PM
Ignition Timing and AFR JB86'd Software Tuning 15 03-16-2015 11:23 AM
How much timing are you running on your FI?!? Fear Forced Induction 4 06-09-2014 02:28 AM
