Drives: RHD Gt86
Intake Cam Timing advanced 20 Degrees at IDLE
Hey guys, as the title asks, how do I go about checking the AVCS timing? Can it be adjusted ?
My car has the intake cam advanced 20degrees at idle :-S Would truly appreciate anyone helpglglglgl
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission Last edited by Kris86; 04-10-2017 at 09:55 AM. |
Drives: UK GT86
How are you measuring that it's 20 degrees at idle? If it's via logging, what are you using? Which bank etc? Same on both? Does it noticeably feel different as it should? It would also likely throw a CEL.
Does it move around if you use the accelerator?
.: Stealth 86 :.
#3 | |
Drives: RHD Gt86
When he go it the first thing he noticed was that the INTAKE cam is at advanced 20 degrees :-/ No engine light ever cam on, and that the weird part it jumps around when u touch the throttle, but it stays in that particular region, while the others stick around -0 - 1 I think also it was on the left head, I'll have to back check if it's both headsgl
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission Last edited by Kris86; 04-10-2017 at 09:56 AM. |
Drives: RHD Gt86
bump! need some help guys.
cant figure out what is causing this up to now. car wont idle on its own even. it also sounds like a extreme unequal length header, meaning missing badly.
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
#5 | |
As Kodename47 said weird it not throwing and CEL codes and CEL light AFAIK cams should all be at 0 at idle. If just one is reading 20 then its possible that cam sensor is bad. but should throw code due correlation error. If its now idling like crap mabe the cam actuator is stuck, but again you would expect cel codes/light. mabe look through these TSB 11-130-13R : Difficulty Starting, Rough Idle, Cam Position, Misfire http://www.ft86club.com/forums/attac...1&d=1375302652 02-132-12 : DTCs Relating to the AVCS (Active Valve Control System) http://www.ft86club.com/forums/attac...0&d=1352490977 |
Drives: 2014 BRZ
You have a JDL kit correct? I am running their kit and the downpipe touches my passenger side Cam Angle Sensor. Lots of others have had this issue, I've wrapped it in a loom and heat tape. Perhaps this could be a culprit?
#7 | |
Drives: RHD Gt86
I will definitely read through the TSB's... I'm taking any advice that comes to me at this point
#8 | |
Drives: RHD Gt86
Yes I do have the JDL kit, I did notice that the down pipe runs rather close to that sensor so I did to a little Fab, but the issue is on the other head
Drives: '15 Subaru BRZ
Have you had the timing chain off of the car?
#10 |
Anti stance.
What is the tune commanding?
#11 | |
Drives: RHD Gt86
Yes I just did a complete engine rebuild, changed rods, pistons, valves, springs and retainers
#12 |
Drives: RHD Gt86
Not sure, I am doing F&G with delicious
#13 | ||
haha, that changes things :-). Still strange the ECU doesn't complain if its commanding zero and the sensor reads 20, that's assuming that's whats happening. |
#14 | |
Drives: RHD Gt86
No codes makes it so much harder
| AVCS - Intake and Exhaust Timing | Kodename47 | Software Tuning | 274 | 02-28-2021 11:39 AM |
| AVCS Explained | Rennmeister | Engine, Exhaust, Transmission | 3 | 03-15-2016 03:12 AM |
| AVCS tuning | Turdinator | Software Tuning | 9 | 11-24-2015 01:31 PM |
| P000A AVCS check engline light? | cookiesowns | Issues | Warranty | Recalls / TSB | 4 | 10-24-2015 01:48 AM |
| AVCS failures? | hmong337 | Forced Induction | 26 | 02-12-2015 03:01 PM |
