Old 07-03-2024, 02:26 PM   #1
SiCaln
Drives: Mini, Own TRD 14R
Installing auto-dimming rear view mirror on Toyota 86 JDM import
So I did as suggested, pulled out the dome light and found the connector in the roof lining, however the 3 pin subaru connector would not fit, looks like my car has a 4 pin connector - any suggestions on where I can get the plug so I can rewire the adapter cable please?
SiCaln is offline   Reply With Quote
Old 07-15-2024, 02:10 PM   #2
removedonut
Drives: 2022 Toyota GR86 Premium 6MT
Are you the same person who contacted me on the other forum for a homelink mirror harness for international models? If not, feel free to PM me. I can build something for this.
removedonut is offline   Reply With Quote
Old 07-16-2024, 08:54 AM   #3
SiCaln
Thank you, I have pm'd you
Maybe 1/1 in the UK TRD 14R owner, check out my youtube channel below
https://www.youtube.com/@GarageeightSix
Old 07-16-2024, 05:25 PM   #4
removedonut
Posting here as well in case anyone else finds this and needs the info in the future: 3-pin mating connector for the autodim mirror is Yazaki 7122-8335.
The Following User Says Thank You to removedonut For This Useful Post:
SiCaln (07-17-2024)
Old 06-17-2025, 01:07 PM   #5
scottryan
Financial Distress
scottryan's Avatar
Drives: 2017 GT86 325WHP
Just want to make sure I'm understanding correctly:
North American / non-JDM 86's will have the standard 3-pin connector hiding in the headliner, which requires a 3-pin to 12-pin harness in order to plug into the autodimming mirror (12-pin in this case, the HomeLink), which can just be bought from Subaru.
However, the JDM 86's seem to have a 4-pin connector instead, meaning we will require that 3-pin adaptor, plug it in, then plug in the 3-pin to 12-pin harness that goes to the mirror.
Am I correct? I have the Homelink mirror laying around and was planning to import a JDM 2012 86 to Canada in 2 years. Just want to make sure I understood correctly!
2017 Toyota 86 - 330WHP Turbocharged
scottryan is offline   Reply With Quote
Old 06-17-2025, 01:13 PM   #6
scottryan
Financial Distress
scottryan's Avatar
Considering importing a JDM 86 in a few years once legal in NA.. I went ahead and subscribed to the YT channel, but was wondering if you have any tips/insight on things to look out for with the JDM ones.
Old 06-18-2025, 12:56 PM   #7
SiCaln
ah thank you, I can assure you a lot of the wiring is very different, even the starlink cable had about 5 wires as opposed to like 20 for US
They also are not undersealed, or have a rear fog but things are pretty easy to add, or change pins, will help anyway I can
DIY: Auto dimming rear view mirror install Longhorn248 DIY (Do-It-Yourself) Guides 64 01-21-2021 07:17 PM
BRZ FRS Gentex Homelink Compass Auto Dimming Rear View Mirror FT86Logic Interior Parts (Incl. Lighting) 2 01-30-2019 11:11 AM
FS: Brand New Auto dimming rear view Mirror skywnsgml Interior Parts (Incl. Lighting) 2 03-23-2016 11:19 AM
Dealer installed option auto dimming rear view mirror. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 23 11-08-2013 05:13 PM
