Old 12-06-2023, 09:33 AM   #295
ThatYeti
Originally Posted by Wally86 View Post
Pull off your garnish and you'll see there's quite a bit of metal behind it and getting it to vent would be more work than I think you're thinking. There are a couple of threads showing how much metal has to be removed.
If you're looking for pure cooling, some naca ducts on the hood might do better to get cool air into the engine bay or pull hot air out. I know marsh has done this with the vents being used to push cooler air into the bay but they could be reversed to do the opposite and pull hot air out.
Recall seeing those but it's been a while since I checked them out, wasn't sure if there was enough space to do that but I'll take your word that there isn't.
For me anyway it's more about having something functional rather than fake, so even if it could be done without the snorkel part I think it could still work and likely help at least some heat escape, but at a minimum wouldn't be just for aesthetics.
ThatYeti is offline   Reply With Quote
Old 12-08-2023, 12:07 PM   #296
orange crush
Drives: Orange FR-S
Trunk pull
Probably helps if I include the STL for the trunk pull upthread.
Things you need:
  • The print
  • Pry tool
  • CA (optional)
  • Loctite Blue (optional)
If metric:
  • M4 well nut (8mm OD)
  • M4 x 35mm socket head screw
If freedom units:
  • 8-32 well nut (5/16th OD)
  • 8-32 x 1 3/8th socket head screw
Directions if not obvious:
  1. Install the well nut in the back recess
  2. (Optional) wick one drop of CA into the gap
  3. (Optional) one drop of loctite blue into the threads of the well nut
  4. Insert the socket head screw into the front, thread it until it just bites
  5. Pop the push pin of your choice off the trunk liner (if you have one)
  6. Insert the assembly in, tighten screw until it stops wiggling.
Be aware that loctite blue can slightly melt/lubricate the well nut, causing it to come apart
orange crush is offline   Reply With Quote
Old 01-15-2024, 02:57 PM   #297
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Designed an intake snorkel like the GR Cup cars. No clue if it fits first gens, *should* fit second gens but haven't had a chance to pull my bumper and triple check my work. It fits the airbox fine anyway, with a bit of weather seal tape.
I designed it to maximize the air intake area into the box while still using thin foam weatherstripping (1/16" thick) and mounting using the OEM grommet.
STL here: https://drive.google.com/drive/folde...9X?usp=sharing
Old 01-25-2024, 11:24 AM   #298
redlined600
redlined600's Avatar
Drives: Fr-s
Originally Posted by DocWalt View Post
I only printed the gurney flap to add to the off the shelf vent, but the end result is a bit similar.
It's split into 3 pieces, the outers hold down the center section.
Printed some blanks for the turn signals
I needed a cover for the A/C.
redlined600 is offline   Reply With Quote
Old 01-25-2024, 09:10 PM   #299
makinen
makinen's Avatar
Drives: Toyota 86
The first gen snorkel exit shape is slightly wider and shorter than the second gen.
The clean one is the second gen.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 02-01-2024, 12:24 PM   #300
DatChinchilla
DatChinchilla's Avatar
Drives: Turbocharged 2015 Subaru BRZ
Do you have the STL file for the side markers? I've been looking everywhere but can't seem to find any.
DatChinchilla is offline   Reply With Quote
Old 02-18-2024, 07:20 PM   #301
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Recently picked up a Elegoo Neptune 4 Max with the intent to make car parts, I’m still new to the 3D printer world so following this thread for inspiration!
kmbkk is offline   Reply With Quote
Old 02-27-2024, 02:44 AM   #302
Jollibee86
Jollibee86's Avatar
Drives: 2014 Scion FR-S
Wanted to share my progress on a custom intake tube for my turbo. 3D scanned the area using photogrammetry (3D zephyr exported to 3ds max).
Then used Solidworks to create the final model
Printed a few prototypes in thin-walled PLA before final one in ABS
Printed in ABS then acetone vapor smoothed
Here it is installed
This picture was taken before the acetone vapor smoothing process
Jollibee86 is offline   Reply With Quote
Old 06-28-2024, 06:03 PM   #303
jody
Driver
jody's Avatar
Drives: Firestorm Red 2013 FR-S
Emblem / Badge
I spent a whole weekend making this near-perfect emblem. It'd make my day to see someone else using it...
Link: https://makerworld.com/en/models/149...ofileId-162918
jody is offline   Reply With Quote
Old 07-01-2024, 06:24 AM   #304
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I got you! (After my current 2 day print gets done lol)
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 07-16-2024, 07:48 PM   #305
TheBoss77
TheBoss77's Avatar
Drives: Toyota 86
Originally Posted by Rzrs View Post
I know I'm reviving an ancient post, and thank you for this. But any chance you could do a blank version where I could drill my own holes for switches?
TheBoss77 is offline   Reply With Quote
Old 09-12-2024, 09:40 AM   #306
Racecomp Engineering
Someone's gotta make side mirrors. My skills aren't quite that good but that would be really cool.
- Andrew
Old 12-09-2024, 04:13 PM   #307
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
This is definitely the coolest car project I've done yet, IMO. I designed new rear swaybar mounts to correct the rear swaybar geometry when lowered and stiffen the mounts. I sent the design off to be 3D printed in aluminum and they arrived today. The whole process was great, the printer communicated with me the whole time and confirmed some aspects of my design. For example, they 3D printed the threads into the mount so I didn't have to tap the holes. So cool!
The design ended up being perfect and everything went together smoothly.
This is the stock geometry, you can see how the swaybar isn't perpendicular to the end link or the ground but it's also not centered on the control arm so it can torque the arm.
My design fixes that
Old 01-08-2025, 11:25 AM   #308
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Designed and printed some stuff inspired by @makinen and his prints.
Battery adapter for my Noco NLP20:
Snazzy looking door mirror "wing" to help with buffeting:
Official DTM Autobody Services Thread for FT86Club! DTMAUTOBODY Southern California 9 12-31-2013 02:09 PM
Official FT86Club Chatroom? wrxgoose Site Announcements / Questions / Issues 13 09-15-2012 05:26 PM
Official FT86Club decal idea? Hanzo Scion FR-S / Toyota 86 GT86 General Forum 71 06-21-2012 08:09 PM
