#281 |
I've not done a lot of 3d printing, but about the only thing I've had real success with is a glass plate. My son has printed dozens of D&D figures on a glass plate and never had an issue.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#282 |
Be Kind
Drives: 2020 86
I've only used glue on a bambu cool plate and I've had nonstop success. It really is 3d printing on easy mode. Only difficult thing I've had to deal with was large flat parts lifting a bit but turning up the bed temps a few degrees fixed that pretty easily. It's an incredibly well tuned machine for sure.
#283 | |
Drives: GR86
Wally86 is right - the Bambu is full-on Easy Mode. The only drawback to that printer (aside from initial cost) is the "walled garden" ecosystem. It's built with their firmware, software, frikkin' cloud infrastructure, and so on in mind. I run mine in LAN-only mode because I'm professionally paranoid (and I do non-zero patent work) and it's still miles more "click and forget" than a Prusa, but it doesn't have all the features. |
#284 |
Drives: '22 BRZ
Doing some ASA prints and I forgot how much it sucks to deal with, bed adhesion wise. Trying a new plate because I'm tired of glue too, my current setup is glass with PEI sheet. No glue for PLA, Nylon, etc. but ASA keeps lifting even with glue and a brim.
#285 | |
Drives: GR86
There's also G10 plates for some printers at lightyeardirect that look like winners - I'll be getting one shortly but I haven't tested yet so I can't vouch for it. I run the textured plate from Bambu with ASA a lot, it adheres well and then once cool the parts are literally just sitting on it, not even a little bit adhered. The Wham Bam is pretty much the same, but it's smooth so the parts are VERY slightly more likely to have a hint of "stick" after cooling. Those two plates are my go-to for 98% of the printing I do. Everything sticks, everything releases. I'm getting the G10 because it specifically says "EVERYTHING" works without glue, and I'm doing PC soon which requires glue on both the textured and Wham Bam plates. Wham Bam makes plates for just about every machine out there, looks like lightyeardirect has a smaller compatibility list. But in any case it should be possible to find a build plate that will do what you want, reliably, and without messy adhesion/release agents. |
#286 |
Drives: '22 BRZ
Using a "Hictop" brand PEI build plate now per the suggestion of a friend with an Ender also printing ASA. Working awesome so far, I did order a Wham Bam PEI plate to try too.
#287 | |
Print Request
#288 |
No experience with 3D printing but curious if anyone's looked into making functional/vented fender garnishes for the first gen cars?
#289 |
Drives: Orange FR-S
Trunk pull
The trunk pull up thread is nice, but it doesn't work for me for two reasons:
1: You need to be able to get a wrench in the back to install it. Can't do that if you have a trunk lid liner 2: It tends to twist because it's a straight bar anchored only in the middle. I made my own version: Installs with an M4 socket head bolt and M4 expansion well nut. Because the universe is kind some times, an 8-32 socket bolt and an M4 socket bolt have dimensions within a percent or two of each other, and a 5/16th 8-32 well nut and an 8mm M4 well nut are again almost identical in size, down to the flange size, so I sized it for both. The one on the car is printed with orange silk PLA, which is OK. First time using it. STL available if anybody cares. |
#290 |
Be Kind
Drives: 2020 86
What would you suggest?
#291 |
Ideally something that mirrors the design of the one for the BRZ but leaves the 'vents' open as functional vents and maybe includes a 'snorkel' of sorts as the panel it opens up to isn't a direct shot into the engine bay
Again this is all from a vantage point of knowing nothing about 3d printing, so whether what i'm asking is feasible in any way i've no idea but thanks in advance |
#292 | |
Be Kind
Drives: 2020 86
That said, I remember a thread for making the vents functional also required cutting in the engine bay behind the fender (on the car side) also. it'd be an interesting project but it'd have to be pretty polished from an internal piece that mates with the new functional vented garnish to a template on where to cut on the fender and in the engine bay.
#293 | |
#294 | |
Be Kind
Drives: 2020 86
If you're looking for pure cooling, some naca ducts on the hood might do better to get cool air into the engine bay or pull hot air out. I know marsh has done this with the vents being used to push cooler air into the bay but they could be reversed to do the opposite and pull hot air out.
| Official DTM Autobody Services Thread for FT86Club! | DTMAUTOBODY | Southern California | 9 | 12-31-2013 02:09 PM |
| Official FT86Club Chatroom? | wrxgoose | Site Announcements / Questions / Issues | 13 | 09-15-2012 05:26 PM |
| Official FT86Club decal idea? | Hanzo | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 06-21-2012 08:09 PM |
