Old 06-24-2024, 09:56 PM   #183
kraftyone
kraftyone's Avatar
Drives: 2020 Subaru BRZ Limited PP
I am at 13.0" front 13.25" rear 6k front spring 9k rear
Sent from my SM-S916U using Tapatalk
kraftyone is offline   Reply With Quote
Old 06-25-2024, 12:00 AM   #184
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Thanks, that's my target.
Currently at 12.75" front, 13.25" rear. 6k/6k springs.
cmiovino is offline   Reply With Quote
Old 06-25-2024, 05:50 AM   #185
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Originally Posted by cmiovino View Post
A couple things. Front bar could go to stiff, rear bar could go to soft. Personally, I'd set the rear to soft. I don't see the need for any larger/stiffer than the 15mm 2017+ on these cars for the rear.
Beyond that, look at your ride height and rake. Most people run a 1/4-1/2" rake at the pinch welds. You'll need more rake with a square spring setup. Less if you're running a staggered spring setup with like 5/7k or 5/9k.
Sidenote: What's everyone running for ride height in 2024? I've been searching over and over on here and it greatly varies. Earlier like pre-2020, people were running ~13.5" center hub to fender and it's gotten down as low as about 12.75" recently as a trend.
I only want to make one comment on this for clarity, 1/4" rake at the hub to fender equates to a bit over 1/16" at the pinch welds, IME.
Lots of the fastest STX cars are running neutral to 0.1" rake at the pinch welds
Old 06-25-2024, 08:17 AM   #186
steverife
Drives: 2016 Scion FRS
All of it is pretty imprecise, IMO. Many of us are eyeballing our measuring, measuring on uneven ground, and so forth.
I measured it at 12.75"/13.25", swapped coilovers in the offseason, measured it at the same in the garage. Then I got to the Charlotte Tour and the front of the car was absolutely shit slammed.
Measured more like 12.5" when I got home. Raised the front of the car roughly half an inch. Didn't touch the rear. Didn't measure anything. Car is much better and seems to have good pace (even though I struggled with it the first few events).
steverife is offline   Reply With Quote
Old 06-25-2024, 08:22 AM   #187
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Yeah, none of that is an exact science. Just ballpark stuff, IMO.
Also, Chris, soften that rear bar. Maybe put a stock rear bar on.
Old 06-25-2024, 12:55 PM   #188
kraftyone
kraftyone's Avatar
I still have the stock bar sitting around, I kept all of the OE stuff I have replaced.
Old 06-25-2024, 06:12 PM   #189
Molez93
Scott M
Molez93's Avatar
Drives: '13 BRZ (DocWalt's old car)
Not sure I'd be considered anywhere close to the "fastest STX cars" mentioned here, but I hold my own. Mine is neutral now compared to about 1/4" rake before the latest MCS coilover install. Results suggest it handles great, and I'm pretty sure my spring rates are equal front and rear
13 BRZ (DSTprep)
14 Lotus Evora S; 08 Exige S240
06 BMW Z4M Roadster, 20 M850
Molez93 is offline   Reply With Quote
Old 06-25-2024, 08:34 PM   #190
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I am very much looking forward to seeing how STX stacks up at the Finger Lakes Tour and saying hi again! Gotta get a pic of your car, my wife's car, and my current BRZ if I take it, haha. Sadly my old ND won't be there lmao
Old 06-25-2024, 08:37 PM   #191
cmiovino
cmiovino's Avatar
A lot comes down to driving style. I prefer a pushier setup myself, at least at the limit. I used to drive a WRX for years so I'm more comfortable like that. I see some other videos and people are seem to be very loose in the rear of the car it seems. That's usually faster, but if you're not comfortable pushing the limit that way, it might not work for you or me.
I'll take your word on it given your experience. I got my info from 949 Racing's recommendations of a 10mm rake at the pinch welds (0.4" inches).
Mine were measured at 4.75 and 5" at the pinch welds running a 12.75" and 13.25" center hub to fender measurement. Confirmed at multiple flat parking lots when setting up the height.
It's possible these 6/9k spring rates people run play a big role here in needing less rake.
Old 06-26-2024, 08:17 AM   #192
Molez93
Scott M
Molez93's Avatar
Makes sense, I think. My preference is definitely to have it tend to oversteer, even dramatically so instead of pushing.
13 BRZ (DSTprep)
Old 06-26-2024, 11:09 PM   #193
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Haven't changed my ride height in a long time, though recently changed camber and toe front and rear.
In any case. 12 7/8" front, 13 1/8" rear, so about 1/4" rake
square springs (400/400)
Really really enjoying how the car is handling this season.
Breezio is offline   Reply With Quote
Old 06-27-2024, 12:08 PM   #194
cmiovino
cmiovino's Avatar
I'm going to assume no axle issues at that height in the rear long term? Care to share your toe settings? I didn't really like 1/16" in with the rear and might go back to zero all around like I ran in DS. It seemed to work for me.
Old 06-27-2024, 11:35 PM   #195
Breezio
Breezio's Avatar
No issues with my stock axles as of yet. Been at this height for 4 years now I think and 10-12 weekends of autox a season.
I also had slight toe in for the rear initially. On my last adjustment I went to zero toe in the rear. To me, the rear end rotation feels much better and more predictable.
Old 06-28-2024, 04:35 AM   #196
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
I was thinking of going back to zero myself now that I have traction mod.(yes yes I know it's not STX legal)
autoracer86 is offline   Reply With Quote
STX setup sharing thread (2022) Autoxer62 Tracking / Autocross / HPDE / Drifting 204 06-15-2023 02:34 PM
STX setup sharing thread (2021) Autoxer62 Tracking / Autocross / HPDE / Drifting 366 12-07-2021 01:57 PM
STX setup sharing thread (2020) Autoxer62 Tracking / Autocross / HPDE / Drifting 389 12-29-2020 01:40 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 11:27 AM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 11:30 AM
