STX setup sharing thread (2020)
I'm new to the group, we bought a Hankone Edition a month ago with the intent of building it later this year for STX. So far I have a line on a couple used parts, and some thoughts for when the budget opens up a little for the big stuff.
Core setup to look like this: [Suspension] MCS two way coilovers, 400 lb springs Karcepts front bar (used part) Adjustable rear bar Keeping the Torsen [Engine] HKS EL header (used part) Tune to match for pump gas Still a lot to fill in. Comments?
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
| The Following 2 Users Say Thank You to Autoxer62 For This Useful Post: | Clutch Dog (01-06-2020), smg1138 (01-06-2020) |
Drives: 2013 FRS
Welcome.
That sounds like a pretty reasonable start. Maybe think about some autox oriented brake pads And a choice on 200 tread wear tires. Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Welcome and congrats on the 86. Check out the Mid Atlantic section of the forum and the BiWeekly Fairfax thread. Good group and a good amount of us autocross with Capital Driving Club and Washington SCCA.
Here’s an example of a full STX build to give you an idea of how far you can take it http://www.ft86club.com/forums/showthread.php?t=129578
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8 |
Thanks for the comments and the link, having a build list is very helpful. I expect to put in poly bushings pretty much everywhere over time unless they don't work - sometimes poly bushings bind things up.
No choice on tires yet, there are frequent enough updates that I don't expect to pick a tire until later. It looks like 17x9 is the wheel size of choice, probably RPF1s. On brake pads, is everyone using the same compound front and rear? Anything to be avoided? Currently I don't expect to do an upgrade beyond pads/hoses/fluid.
#5 | |
Look at the FRS cars that all have won nationals, going back to when they were first introduced into STX - you'll see none of them were ever full-tilt prep. To this date - only one even had an OSG (Lugod). The only bushings you should prioritize is the whiteline insert bushings for the subframe. Every other one, can wait...IMO. This is the only bushing set I've done. I run DS2500s F/R. I think they're the best overall pad you can get. Many options to choose. I don't think splitting pad compounds is the best idea.
Kyle H. - #89 STX
| The Following 2 Users Say Thank You to M0nk3y For This Useful Post: | justint5387 (01-08-2020), strat61caster (01-07-2020) |
Drives: 2016 Scion FR-S
I think the ideal STX setup needs to be built around an OS Giken STX-Tuned 1-Way LSD. I believe the LSD lets you run stiffer rear springs and properly utilize a stiffer front sway bar. Not sure if a 1-Way from another manufacturer will work equally as well.
From the previous STX threads, this is what you want: - OS Giken STX-Tuned 1-Way LSD - 5k Front Springs/9k Rear Springs - 4.2 Degrees Camber Front / 2.8 Degrees Camber Rear - 22mm Front Bar - 13mm Rear Bar (Mann Engineering) |
#7 | |
Drives: '22 BRZ
That sounds VERY loose... That said, the math says the normal setup should be really pushy based on ride frequency, so who knows. I will say, a 1 way diff doesn't seem like a great idea and I have a Giken in my STR car so it's not biased against after market diffs.
Whats the go to front control arm bushings? That are not Whiteline. Sick of their stuff failing. Stock or is there something else?
| The Following User Says Thank You to ka-t_240 For This Useful Post: | Clutch Dog (01-08-2020) |
#9 | |
Drives: 15 Impreza
Rallispec has some STI hardened bushings for the front control arms that I have been eyeing up. http://www.rallispec.com/mou_bush_rstbkbrz.html |
#10 |
Drives: 2013 Subaru BRZ Premium MT
I switched to SuperPro bushings. I've had better experience with those.
Sent from my SM-G930P using Tapatalk |
#11 |
#12 |
The SuperPro are simply polyurethane, with the metal sleeve section for the bolt, like the Whiteline ones. The polyurethane seems to be a different hardness, though.
#13 | |
Do you have any pics of them? Are they 1 piece like OEM or 2 piece like the whiteline? |
#14 |
I don't have pictures, and it's been a long time since I worked on it, so I looked up the install instructions.
There are two bushing locations in the front control arms. The front ones are one piece, the rear ones are two piece. I forgot that the front ones have a new sleeve that replaces the OEM bushing sleeve, which makes sliding in the new polyurethane easier. Sent from my SM-G930P using Tapatalk |
| SSC setup thread | conehead | Tracking / Autocross / HPDE / Drifting | 26 | 06-06-2023 02:21 PM |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 109 | 02-17-2020 11:27 AM |
| STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 11:30 AM |
| Official Roll Cage/Bar Thread **Show off your setup!** | slava | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 01-02-2015 10:05 PM |
