Old 05-27-2024, 07:57 AM   #1
tobin
tobin's Avatar
Drives: '13 BRZ
JDM STI damper kit (with questions)
I am replacing the original suspension on my '13 BRZ and ordered this kit from Japanparts. There wasn't a lot of info, so I wanted to share.
Question: No top nuts for the strut shafts were provided. Do I reuse the stock nuts? For the rear, do I reuse the bump stops and boots?
Kit: STI
DAMPER KIT (ST20310AS040 + ST20310AS050 + ST20365AS020x2 + ST20330AS010x2 + ST20380AS020x2)
(Japanparts No : 484-050-001)
Strut F RH: ST20310AS040 x 1
Strut F LH: ST20310AS050 x 1
Shock Absorber R: ST20365AS020 x 2
Coil Spring F: ST20330AS010 x 2
Coil Spring R: ST20380AS020 x 2
Delivery took less than two weeks from Japanparts. Here's what I received:
Front Struts
Front Springs
Rear Struts
Rear Springs
tobin is offline   Reply With Quote
Old 05-27-2024, 07:46 PM   #2
ZC6_STi
ZC6_STi's Avatar
Drives: 2015 Subaru BRZ Series.Blue #709
Yes, you can reuse the top hats and stock nuts from the stock suspension. You're just switching out both the struts and springs. Make sure to use a spring compression tool to compress those springs during removal.
You can get new top hats and if you don't want to break your wallet, I suggest Pedders Front Top Hats since there isn't much aftermarket for the rears. Otherwise, keep the OEM parts.
https://www.ftspeed.com/products/580...nt-strut-mount
ZC6_STi is offline   Reply With Quote
The Following User Says Thank You to ZC6_STi For This Useful Post:
tobin (05-28-2024)
Old 05-27-2024, 08:45 PM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
If the front strut is inverted like Bilstein B6s the hump stop is Likely internal. No need to do anything on the front.
Rears you would reuse OEM assuming the springs are stock height.
The Following User Says Thank You to RToyo86 For This Useful Post:
tobin (05-28-2024)
Old 05-28-2024, 06:25 AM   #4
tobin
tobin's Avatar
Drives: '13 BRZ
Thank you for the info. A shop will be doing the install. I have a new set of Pedders mounts ready to go, along with a new set of rear OEM mounts, and new front and rear stabilizer bar end links.
ATI Damper? themadscientist Engine, Exhaust, Transmission 0 01-07-2023 12:17 AM
FRS VS BRZ Damper (strut) kilohercas Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 09-24-2015 03:11 PM
FRS VS BRZ Damper (strut) kilohercas FR-S / BRZ vs.... 1 09-24-2015 03:19 AM
Damper rates mikepaul21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-03-2014 08:23 PM
Damper crosstalk ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-01-2013 02:21 AM
