Old 05-13-2024, 09:51 PM   #1
Stevedave
Drives: 2013 Scion Frs
Car Stalls at Idle
I was thinking about cleaning the throttle body and MAF.
Any thoughts?
Stevedave is offline   Reply With Quote
Old 05-14-2024, 03:54 AM   #2
Take it to a pro who knows how to record and interpret engine performance logs.
Stevedave (05-17-2024)
Old 05-14-2024, 03:14 PM   #3
Originally Posted by Stevedave View Post
I don’t know of any in my area, or even within a couple hours radius. I don’t even trust the Subaru dealership to touch it, let alone the Toyota dealership.
Is there anything that plugs into the OBD II port that can be purchased off Amazon or something?
No offense intended. I used to dive into this with anyone until I learned to gauge experience in the context clues. This takes years of experience. Use Google to search this forum, and keep a humble frame of mind.
It might be as simple as an intermittent connection to your MAF but without the diagnostic tools, and especially the knowledge to use them, it's just poke-and-hope.
See the link to service manuals in my sig line.
Old 05-14-2024, 04:44 PM   #4
Stevedave
None taken
Thanks for your input.
Last edited by Stevedave; 08-22-2024 at 07:44 PM. Reason: Info not useful to issue
Old 05-16-2024, 04:33 AM   #5
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
Is check engine light on? Change o2 sensors, look for any vaccum leaks hoses ect. Lastly could be maf sensor on intake
sweetfrs is offline   Reply With Quote
The Following User Says Thank You to sweetfrs For This Useful Post:
Old 05-16-2024, 10:16 AM   #6
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Although I agree to noting if the check engine is lit and to check for vacuum hose leaks, those visuals are just PART of thorough diagnosis. Let's not throw parts at it and waste time and money. He needs to pick up a good scanning tool to create logs that we can help him interpret. I would recommend the OBD LINK MX+ in his case and a good android tablet with the app to go with it.
https://www.obdlink.com/products/obdlink-mxp/
No I'm not a spokesperson for the company, I actually use this tool on many of the vehicles that I drive and troubleshoot. It's not an ECUTEK-level tool when it comes down to logging, but it's the next best thing I use when I'm not in the mood to connect my laptop to my car and it should get the job done for what he needs.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post:
Stevedave (05-17-2024), Ultramaroon (05-16-2024)
Old 05-16-2024, 12:51 PM   #7
Stevedave
No dash lights.
Old 05-16-2024, 01:25 PM   #8
I’d very much like to go the scanning tool route. I have an android tablet, but it’s dated. I don’t have a laptop as I have a pc. That leaves me with an iPhone.
Are there any scanners you’d recommend?
For what it’s worth; car was detailed yesterday. Part of the process was bombing it with the AC on recirculate while it idled for ~35 minutes. It did not stall. I stood next to it while this was being done. I could hear the rpms dip, but as the compressor kicked on the idle would raise up, I think keeping it from stalling. I’ve read this is common on these cars. I drove it home with the AC on and even though I didn’t idle for any longer than a couple mins at stop lights, it didn’t stall. I did notice the same thing with an idle dip but either the cooling fans or the compressor kicking back on brought the rpm’s back up.
I have the same device working with a tablet as old as the car. It's good software and a good tool.
Do not throw parts at it. Read the manuals. Learn to diagnose properly.
Old 05-16-2024, 02:08 PM   #9
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
The MX+ is also iPhone compatible. However, I like to use my cheap 10" DVD player/tablet running Android 10 because of the large screen and its ability to sit at any angle I want it to.
Edit: By the way, that crack in the pipe is just on the inlet to the sound generator tubing leading to the firewall. It won't make a difference at all to the operation of the fuel system since it's before both the air filter and MAF sensor.
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
Old 05-16-2024, 03:39 PM   #10
Well, now I have to correct that for the record. It's the last helmholtz resonator upstream of the filter element. Still not a big deal.
Stevedave (05-17-2024), Turdinator (09-05-2024)
Old 05-17-2024, 12:59 AM   #11
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Thanks,...Tcoat.
Old 05-17-2024, 02:12 AM   #12
Stevedave
Perfect. Thanks!
Old 05-17-2024, 03:45 PM   #13
Thanks,...Tcoat.
Old 05-24-2024, 07:25 PM   #14
tomm.brz
Drives: brz 2017 hksv2
sound deadening and some thermal insulation i guess
tomm.brz is online now   Reply With Quote
Stevedave (06-01-2024)
Car Stalls at Idle Stevedave Engine, Exhaust, Transmission 0 05-13-2024 09:36 PM
OFT Stalls on Cold Start scsftballnum45 Software Tuning 15 02-17-2019 04:13 PM
BRZ down... Stalls right after start bravedeer Issues | Warranty | Recalls / TSB 12 09-12-2018 07:39 AM
HELP! BRZ 2017 stalls when switching to OL Muchikori Software Tuning 5 05-27-2018 12:16 PM
FR-S - AT nearly stalls when stopping WryGuy Issues | Warranty | Recalls / TSB 12 05-27-2016 04:04 PM
