Old 06-15-2017, 12:11 AM   #29
electrongeek
Drives: 2016 Scion FRS
Originally Posted by JT.86 View Post
I'll do a write up of what my pins are tomorrow
Sent from my ONEPLUS A3000 using Tapatalk
Awesome thanks!
electrongeek is offline   Reply With Quote
Old 07-25-2017, 10:10 PM   #30
iyoiyo
Drives: 2016 - FRS
have you guys get the DRL working properly? I have everything working except the DRL. my temporary solution is wire the drl to the turn signal, so it lit up during the night time or turn on the light switch, but not working in day time. my DRL resistor wire is not getting power at all when engine is on with only 0.5V instead of 12V
iyoiyo is offline   Reply With Quote
Old 12-22-2020, 12:27 AM   #31
Kynans
Ultra Junior Member
Kynans's Avatar
Drives: 2013 Scion Frs First Edition
Reviving this thread, I recently bought a set of the Valenti headlights, I own a 2013 frs and also got a morimoto xb d series 3500 hid retrofit kit with the relays, ballast, and igniters. I am pretty sure I figured out the headlight harness wires. Next is to repin my 6 pin harness and figure out the signal wires. I have attached a photo to what I think the wires correspond to. Let me know if it looks wrong, and if you have any tips on how to wire the dual filament parking/signal lights!
Sent from my SM-N975W using Tapatalk
"I like to pretend I'm fast but I'm really not"
Kynans is offline   Reply With Quote
Old 12-23-2020, 07:41 AM   #32
Tomm
Identifying as a Member
Tomm's Avatar
Drives: 2013 FRS LS1
You may want to use this wiring harness diagram (for an FRS): https://drive.google.com/file/d/0Byp...1GY3hNTkE/view
It helps when you're repinning to look at these diagrams by function rather than color, use the color to orient yourself to the right harness plug and source. Only look at the pinning of the plug you're changing - so the link I provided above is the harness pin out from the chassis (not from the headlight). The headlight harness (from the HIDs/bulb) will be mirrored. So when you go from 6 to 8 pin, do all the repinning on your chassis harness and then worry ab the parking light power supply.
The parking lights can be done a variety of ways but I tapped into the parking brake resistor box power supply. Heres a vid of what I did:
By doing that, the parking lights will remain on just as OEM does and you can still use always on modules if you so choose. You can just go crazy and hook up power from anything to the parking light but without a resistor they are pretty bright at least on the monograms, so a resistor is necessary to calm it down.
Let me know if you're now thoroughly confused. Or someone else chime in if I'm wrong.
In the midst of an LS1/T56 swap build page here or follow me on YouTube or IG.
ACT Clutches - APEXi - Buddy Club - Carbing - DBA - Diode Dynamics - Fidanza - HKS - ICT Performance - Project Kics - RPM Transmissions - SEIBON - Sikky Manufacturing - SPC - Tick Performance - TK Style - VERUS - VOLK - Whiteline
Tomm is offline   Reply With Quote
Old 02-07-2023, 01:01 AM   #33
Kynans
Ultra Junior Member
Kynans's Avatar
Thanks for all the help on this! Install was a pain but is looking good.Name:  20221026_182112.jpg
Old 04-04-2024, 09:40 PM   #34
scottryan
Financial Distress
scottryan's Avatar
Drives: 2017 GT86 325WHP
Originally Posted by Kynans View Post
Thanks for all the help on this! Install was a pain but is looking good.Attachment 218518
Second revival.. is the diagram you shared what I should follow when re-pinning? Any new tips you'd want to add in?
I'm looking to fit these onto a 2017 GT86 (Also in Canada), pulling the trigger on a set of these and am gauging the work I have cut out for myself. Any shot at being able to re-use the OEM bulb off the 2017+ headlights? Or need to run an aftermarket HID ballast?
Thanks in advance. Great build
Edit: Partially answered my own question, you can re-use the HID bulb and D4S Ballast off BRZ models, but the FRS (Non-10-series) and 2017+ 86 you will need a new ballast and bulb.
scottryan is offline   Reply With Quote
Old 04-17-2024, 08:51 AM   #35
scottryan
Financial Distress
scottryan's Avatar
Adding to the thread for any 2017+ Toyota 86 owners, here's your harness diagram attached. Tested all harness functions myself, then flipped over to a Toyota Master Technician to verify.
EDIT: WHITE and GREEN on the Valenti harness below need to be swapped. Other than that everything I've posted is 100% confirmed!
What this means is if you have a 2017+ 86, you need to repin 3 different pins:
- Orange goes from 1 --> 3
- White goes from 2 --> 1
- Green goes from 3 --> 2
Green is the actual "blade" LED that this headlight features. White is the lights below the turn signal, make sure whatever your regular running light is, goes to the Green wire.
Last edited by scottryan; 05-12-2024 at 11:19 AM. Reason: updated information for accuracy!
BRZ Headlight pin/wiring diagram 2SeeKU Electronics | Audio | NAV | Infotainment 12 06-28-2020 02:17 AM
WTB BRZ OEM headlight ballasts and wiring Hot Wheels Want-To-Buy Requests 0 05-15-2016 04:51 PM
headlight wiring problem VakaGT Cosmetic Modification (Interior/Exterior/Lighting) 0 12-30-2014 02:41 AM
headlight wiring question Lydin Cosmetic Modification (Interior/Exterior/Lighting) 0 04-11-2014 10:02 PM
So is there a DIY yet for BRZ headlight wiring for the FR-S? seven Cosmetic Modification (Interior/Exterior/Lighting) 4 11-25-2012 09:24 PM
