Old 04-17-2017, 12:29 AM   #1
electrongeek
Drives: 2016 Scion FRS
Valenti Headlight Wiring Help
I'm in need of some guidance on wiring up some Valenti Headlights. Anyone that has successfully done this please chime in. I tried searching, but didn't find any specific tutorials.
Any input would be appreciated. Thanks.
electrongeek is offline   Reply With Quote
Old 04-17-2017, 01:03 AM   #2
thecarfilmer
IG: @nickwiththefrs
thecarfilmer's Avatar
Drives: 2016 Scion FR-S Halo
from what ive seen about those headlights, theyre meant for RHD cars but i vould be wrong. dont take my word for it lol
thecarfilmer is offline   Reply With Quote
Old 04-17-2017, 01:39 AM   #3
electrongeek
Yes, you're correct. Normally that would be an issue, but I have modified the projector cut off shield so that it no longer blinds oncoming traffic.
All I need to do now is figure out the wiring schematics so that I can create a harness.
Old 04-18-2017, 02:03 PM   #4
JT.86
Drives: Scion FRS 2016
how did you do that?
___________________
2016 MT|Varis Arising II body kit with carbon add-ons|Aimgain x Stancenation Spoiler|Valenti Japan Jewel headlights|Valenti 4th Brakelight|ST-X coilovers|SPC LCA|18x10 TE37RT|Hankook Ventus RS3 265/35|Work Chrome blue lugnuts|Corsa catback|JDM TOM's red taillights|JDM armrest|TRD carbon Fender garnish|Beatrush Rear bumper brace|Cusco front strut
JT.86 is offline   Reply With Quote
Old 04-18-2017, 02:06 PM   #5
electrongeek
I had a friend of mine mill the cut off shield so that the step in the beam pattern is now flat.
Do you have Valenti headlights? Have you successfully wired them up?
Old 04-18-2017, 02:09 PM   #6
JT.86
I see.
I'm still in the process of figuring the wiring out
Sent from my ONEPLUS A3000 using Tapatalk
___________________
Old 04-18-2017, 02:14 PM   #7
electrongeek
I see.
I was going to see if I can swap the RHD projectors out for some LHD Morimoto projectors, but I decided to stick with the existing projectors so that I can use the OEM hid ballasts and bulbs.
If you're able to figure out the wiring then please post it here. I'm also trying to work out the wiring myself so I'll post it up as well if I'm successful.
Old 04-18-2017, 02:21 PM   #8
JT.86
I'm trying to figure out how the wires should be wired from the car end atm. The frs high beam bulbs is also the DRL which runs through a resistor. Not sure how this can be adjusted to run the valenti headlights where the high beam and low beam are the same light.
___________________
Old 04-18-2017, 04:19 PM   #9
electrongeek
I remember seeing a tutorial on how to repin the 8 pin Japanese GT86 headlights to work with the FRS 6pin.
If the Valenti headlights are direct plug and play for the Japanese GT86 then I would assume the repin method should work.
I already bought the necessary plugs to create a harness so hopefully my assumptions are correct.
Old 04-18-2017, 04:21 PM   #10
DrifterD
Drives: 15' Halo
I've been trying to do research on this as well before I decide to get them since they are the nicest headlights out for this car. From what I've heard its plug and play if you have the OEM D4S ballast, not sure if morimotos will work.
Subbed for solution.
2015 Halo MT
@denneee
@haroseattle
DrifterD is offline   Reply With Quote
Old 04-18-2017, 04:22 PM   #11
JT.86
Japanese gt86 doesn't have drl/highbeam as same bulb right? Or is everything the same as frs except led drl strip?
___________________
Old 04-18-2017, 04:23 PM   #12
JT.86
Definitely not plug and play
___________________
Old 04-18-2017, 04:24 PM   #13
electrongeek
Yes, I'll be using the OEM D4S ballasts and bulbs.
I assume you're saying it's plug and play for the Japanese GT86?
Old 04-18-2017, 04:25 PM   #14
DrifterD
Drives: 15' Halo
Probably, my bad.
2015 Halo MT
@denneee
@haroseattle
BRZ Headlight pin/wiring diagram 2SeeKU Electronics | Audio | NAV | Infotainment 12 06-28-2020 02:17 AM
WTB BRZ OEM headlight ballasts and wiring Hot Wheels Want-To-Buy Requests 0 05-15-2016 04:51 PM
headlight wiring problem VakaGT Cosmetic Modification (Interior/Exterior/Lighting) 0 12-30-2014 02:41 AM
headlight wiring question Lydin Cosmetic Modification (Interior/Exterior/Lighting) 0 04-11-2014 10:02 PM
So is there a DIY yet for BRZ headlight wiring for the FR-S? seven Cosmetic Modification (Interior/Exterior/Lighting) 4 11-25-2012 09:24 PM
