Old 11-20-2013, 04:51 AM   #1
2SeeKU
Drives: Raven GT86 & Subaru WRX CS6
BRZ Headlight pin/wiring diagram
Hey guys,
I'm installing a set of BRZ headlights on my GT this weekend and was just wondering if anyone has the wiring diagram for the headlight connector.
I believe it's (for the right headlight):
[Pin 1] White - Red Stripe : Indicator
[Pin 2] Blank
[Pin 3] Red : Parkers
[Pin 4] Black: Ground
[Pin 5] Blue : Low beam
[Pin 6] Black - White Stripe: Ground
[Pin 7] White - Blue Stripe: High Beam
[Pin 8] Black - White Stripe: Ground
I've got the plugs/connector, so the plan is to simply repin the BRZ connectors.
Also, does anyone know of a indicator replacement for the GT/FRS? As l'll have the indicator in the headlights l was thinking of removing the stock GT ones.
Cheers!
2SeeKU is offline   Reply With Quote
The Following 2 Users Say Thank You to 2SeeKU For This Useful Post:
Efferalgan (06-03-2014), Lonewolf (06-16-2014)
Old 11-21-2013, 05:44 PM   #2
2SeeKU
Looking through the wiring diagram for the BRZ and it looks correct, although l just have the left/right switch.
Old 06-03-2014, 04:01 PM   #3
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Thanks for the diagram! I'm planning to install Spec-D headlights on my GT86 and put the Chargespeed bumper on w/o any light elements.
Efferalgan is offline   Reply With Quote
Old 06-15-2014, 09:06 PM   #4
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Where did you purchase your BRZ headlights @2SeeKU?
AVodka14 is offline   Reply With Quote
Old 06-16-2014, 07:19 AM   #5
2SeeKU
From another member who was parting out their car. Right place, right time!
The Following User Says Thank You to 2SeeKU For This Useful Post:
AVodka14 (06-16-2014)
Old 07-19-2017, 09:57 PM   #6
Hawker271
Drives: Scion FR-S 2013
Sorry for Bumping. Anyone wire it so that the boomerang is always on?
Hawker271 is offline   Reply With Quote
Old 04-23-2018, 12:38 AM   #7
Sel_brz17
Sel_brz17's Avatar
Drives: BRZ 2017
so the pins can come off? no cutting of wires required??
Sel_brz17 is offline   Reply With Quote
Old 08-02-2018, 02:53 AM   #8
Thaeyo
Thaeyo's Avatar
+1 I need help too. I've been able to wire the BRZ boomerang as DRL or on with headlights. But not both.
I've even tried setting the boomerangs to function with parking/headlights, then double tapping both LED wire to the DRL wire (green wire on passenger side, also removed the resistor).
Any help in the right direction would be nice!
Thaeyo is offline   Reply With Quote
Old 08-15-2019, 02:10 PM   #9
BOND007_LTK
Drives: 2013 brz
Not sure if you guys ever got the answer but there is a thread on here that involves getting diodes and stuff. Cheaper but somewhat complicated.
I got the always on kit and love it. Because it dims the drl which is always on too at night which is inportant as they are very bright. Its plug and play. Vs finding the diode current etc etc.
BOND007_LTK is offline   Reply With Quote
Old 08-17-2019, 03:25 PM   #10
Thaeyo
Thaeyo's Avatar
I was able to wire a tap-a-fuse through the firewall to the interior fuse box for always on, took a little more work, but its working
Old 01-21-2020, 07:35 PM   #11
iconic
Drives: 2015 Scion FRS Auto
Anyone know which pin position on the 8 pin connector is the DRL?
iconic is offline   Reply With Quote
Old 06-25-2020, 05:13 PM   #12
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Do you remember which fuse by chance?
Is it the ones labeled “Parker” on the first post?
Old 06-28-2020, 02:17 AM   #13
Magoo
Magoo's Avatar
Drives: 2013 Scion FRS
That's the way I interpret it.
I am trying to get the DRL to work in the spot on the BRZ light that was the turn indicator. I disconnected the resistor, ran a wire from the green wire plug to the spot on the new BRZ light connector (spot 8, green wire), but no luck. Fuse is good.
Any ideas? Will the BRZ yellow bulb not work as a DRL?
Magoo is offline   Reply With Quote
Official 2013 Scion FR-S & Subaru BRZ Electrical Wiring Diagram azian_advanced DIY (Do-It-Yourself) Guides 16 09-09-2017 04:18 PM
DIY: Alarm installing wiring diagram trueno86power DIY (Do-It-Yourself) Guides 17 02-07-2014 09:03 PM
Wiring Diagram for base radio? -max- Electronics | Audio | NAV | Infotainment 2 12-19-2012 04:39 PM
So is there a DIY yet for BRZ headlight wiring for the FR-S? seven Cosmetic Modification (Interior/Exterior/Lighting) 4 11-25-2012 09:24 PM
AWD FT-86 Diagram AaronCompNetSys Scion FR-S / Toyota 86 GT86 General Forum 52 11-22-2011 01:53 PM
