| Software Tuning Discuss all software tuning topics. |
Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Advice Needed again ECU Replacement or Recover Some how?
So finally got my turbo kit installed went to go start up with OFT and I can't pull the factory read.
From what I gather as this car may of been tuned with ECU tek or something else before. What is my best method of attack on this one?
797Performance.com
#2 |
You should be able to load stock tune with OFT. Google it you should find a procedure.
#3 | |
AutoX-10/10ths every run
https://www.ft86club.com/forums/showthread.php?t=130726 The answer you are looking for is probably in that thread.
#4 |
Drives: brz 2017 hksv2
probably ecutek but you need a kit to check it
if you find a cheap ecu from a totaled car ( ive found one for 95 dollars shipped for example) you can swap it directly if it s same transmission and same year ( with some tolerance but need to know what it has to check compatibily) With a tactrix you can take any ecu from any year and reprogram it before marrying it with oft |
#5 |
Ned flanders
I ended up ordering a used Computer off ebay with the same part number, I will get that swapped in and hope for the best. After discussing with a tuner and not knowing what it was tuned on before I dont wanna just keep buying stuff lol
797Performance.com
#6 |
should work
just do the ecu swap procedure and then marry it with oft |
| 949 lug nut advice needed | doug1234 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 03-02-2021 01:39 AM |
| Some advice needed please | pevsfreedom | Engine, Exhaust, Transmission | 0 | 10-20-2019 09:34 PM |
| Advice Needed -- DD for $1K | carczar87 | Other Vehicles & General Automotive Discussions | 29 | 10-05-2017 08:10 PM |
| What to do.. Advice needed | fuddbutter | AUSTRALIA | 44 | 01-29-2013 08:02 AM |
