Advice Needed again ECU Replacement or Recover Some how?
So finally got my turbo kit installed went to go start up with OFT and I can't pull the factory read.
From what I gather as this car may of been tuned with ECU tek or something else before. What is my best method of attack on this one? |
You should be able to load stock tune with OFT. Google it you should find a procedure.
https://www.ft86club.com/forums/showthread.php?t=130726 The answer you are looking for is probably in that thread. |
probably ecutek but you need a kit to check it
if you find a cheap ecu from a totaled car ( ive found one for 95 dollars shipped for example) you can swap it directly if it s same transmission and same year ( with some tolerance but need to know what it has to check compatibily) With a tactrix you can take any ecu from any year and reprogram it before marrying it with oft |
I ended up ordering a used Computer off ebay with the same part number, I will get that swapped in and hope for the best. After discussing with a tuner and not knowing what it was tuned on before I dont wanna just keep buying stuff lol
should work
just do the ecu swap procedure and then marry it with oft |
| All times are GMT -4. The time now is 07:38 PM. |
User Alert System provided by
