Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 03-15-2024, 07:03 PM   #1
OldBiker
Drives: 2023 Gray BRZ
Oil Pressure Drop
Latest from 900BRZ:
Yeah!! So the best solution: large capacity oil plan + integrated baffle. Excellent video to go along with it, explaining the experiment and logic. Can't wait to see the final product!
OldBiker is offline   Reply With Quote
The Following 6 Users Say Thank You to OldBiker For This Useful Post:
BatStig (03-16-2024), CaptainFenderbaum (03-16-2024), Gearhead23 (03-16-2024), vindiesel (03-16-2024), whataboutbob (03-15-2024), ZDan (03-24-2024)
Old 03-24-2024, 09:14 AM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yeah, that looks like the ultimate answer. Meanwhile before pan is available, Accusump looks like the best solution at the moment.
Tryna decide whether to go ahead and get Accusump and then the deeper aftermarket oil pan solution when it is available, or get an ND2...
Old 03-24-2024, 11:25 PM   #3
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
ND2 is tremendous amounts of fun but that suspension is way to soft for anyone who wants to be competitive. I personally would get one for a sunday driver but not necessarily a time attack or track rat.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 03-25-2024, 05:42 PM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yeah no way it would stay on stock suspension, would be getting coilovers, roll bar, and a lower and more supportive drivers seat right away. We are spoiled with BRZ seats!
Old 03-25-2024, 10:00 PM   #5
Dirty Harry
Dirty Harry's Avatar
Drives: 2013 BRZ Satin White Pearl
So you think the issue is that serious that you’d swap cars? Pretty big call. I don’t know heaps about the issue, but it sounds like it’s the main flaw with the new one. So the first gen didn’t have these types of issues at all?
Dirty Harry is offline   Reply With Quote
Old 03-25-2024, 10:52 PM   #6
whataboutbob
AutoX-10/10ths every run
Originally Posted by Dirty Harry View Post
So you think the issue is that serious that’d you’d swap cars? Pretty big call. I don’t know heaps about the issue, but it sounds like it’s the main flaw with the new one. So the first gen didn’t have these types of issues at all?
I'm pretty sure the 1st gen had issues. Especially if; 1) You let the oil get low and then drove it hard, 2) Added FI, and/or: 2.a) Let the oil get low, 2.b) Drove it hard, 2.c) Didn't address the oil cooling issues, 2.d) Had a shitty motor build (OEM or aftermarket), or 2.e) All of the above
Build thread:Here
Old 03-26-2024, 07:53 AM   #7
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Oil pressure wasn't great if oil temps were too high on the first gen. Lots of info on this online
On the second gen oil pressure will drop on track based on load from right hand turns regardless of the temperature.
Street driving seems to be fine so if you don't track your car its not much of an issue
autoracer86 is offline   Reply With Quote
Old 03-26-2024, 10:30 AM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
1st-gen isn't perfect in this regard, but the 2nd-gen definitely has an issue with pressure drops under track usage, particularly during right-handers on decently-suspended cars with higher-grip tires.
I tracked my 1st gen ~12 track days/year for five years, I wasn't monitoring oil pressure though.
Anyway I test-drove an ND2 last year and it was a hoot, reminded me a bit of my old 240Z being similar weight (slightly heavier) and with driver sitting right at the rear wheels. I got the '23 BRZ because more utility as it was going to be my only car. Since then I've picked up an '05 Mazda3 hatch as a daily so the ND2 is more of an option now. Also I've been having to run a ton of ballast for time trials, and for this year they've added 80 lb. more Victory ballast... So anyway my competition weight with the '23 BRZ would be 3187 lb. this year. Kinda nullifies one of the best things about the car... Even at 3107 lb. last year I could *feel* the mass. Could run ND2 at 2475 lb. which sounds like fun...
Dirty Harry (03-27-2024)
Old 03-26-2024, 12:14 PM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
*What* oil cooling issues? My gen-1's oil temp always went to 270-275F *indicated*, every session for 5 years, ~50 track days, never went beyond that. 275F indicated oil temp has been correlated to 255F sump temp. These temps are no prob at all for any decent synthetic oil.
Data shows that measured oil pressure with 5w30 is the same with an oil cooler at 250F, as with NO oil cooler at 275F. I.e., pressure drop from the oil cooler is equal to pressure drop due to higher temp with no oil cooler.
And anyway you can easily go to 40-weight if want higher pressure at temp with no oil cooler.
I did a pretty exhaustive search when I got my car in late 2017 and found that engine failures were not correlated at all with whether or not an oil cooler was present. In fact it seemed to me that *most* track failures were *with* an oil cooler. There were RTV issues and general oiling issues particularly for #3 not related at all to oil temperatures.
Again, 275F indicated/255F sump was never the problem...
blsfrs (03-26-2024)
Old 03-26-2024, 12:46 PM   #10
autoracer86
Drives: Toyota GT86
Do you have this saved to a text file ? LOL
The Following 3 Users Say Thank You to autoracer86 For This Useful Post:
blsfrs (03-26-2024), timurrrr (03-27-2024), ZDan (03-26-2024)
Old 03-26-2024, 01:48 PM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
I should...
Old 03-26-2024, 06:30 PM   #12
OkieSnuffBox
Drives: '23 BRZ Limited
The seeming requirement of engine, transmission, diff coolers after 949's and FM's testing is kind of a bummer.
And FM has stronger case bolts for the transmission because the case itself twisting was found to be the reason cars tracked hard were having transmission failures.......I don't remember if they made the cases stronger for ND2s.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 03-27-2024, 11:39 AM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
Thanks for the food for thought! I had thought the fragile gearbox had been fixed by ND2, looking into it... Ditto for trans and diff cooling. Just joined forum.miata.net and posted up Qs on the track forum.
Old 03-27-2024, 11:56 AM   #14
Petah78
Drives: 2022 BRZ sport-tech
Interesting, i have heard that the ND2 has a glass trans which never got resolved this is up to 2023. The only solution was to swap in a NC 6sp. This is the first i have heard about the requirement for a diff/trans/engine cooler.......
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
900brz, fa24, oil pressure
Ansix Auto FA24 BRZ/GR86 Accusump Oil Pressure Drop Testing Results Ansix Auto GR86 General Topics (2nd Gen 2022+ Toyota 86) 49 09-14-2023 09:35 PM
Should an oil cooler cause oil pressure to drop? blsfrs Engine, Exhaust, Transmission 6 07-30-2023 10:28 PM
Fuel Pressure Drop on my LS BRZ Shahano Engine Swaps 6 04-28-2021 05:57 PM
Intermittent fuel pressure/signal drop (Fuel regulator prob?) Decimus Issues | Warranty | Recalls / TSB 6 03-27-2019 08:38 PM
Temperature drop, tire pressure check! radroach Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 11-07-2016 09:43 PM
