Drives: car
Temperature drop, tire pressure check!
Just a reminder everyone, daylight savings time changeover and also it's cold, your tires have probably dropped 5 psi if you haven't checked over the last couple weeks, so get out the tire inflator and put some air in if you need it!
#2 | |
humfrz |
Drives: 2015 FRS
i think its a reminder to swap on those winter tires
Drives: car
@humfrz maybe, my car starts slower than usual when cold, slower than it usually did 3 years ago and still on stock oem Panasonic battery. I've had to do a couple jump starts last year after running my emergency lights.
But for tires, I recommend keeping an eye on your tire presssure temps during autumn. Our southern sunny 90*F weather here is going to start dropping to the 50* soon. I had 5psi drop out of each tire and couldn't figure out what had happened to my handling, @CSG_mike said my struts were worn, but really we just had cold mornings and my tires were low. Last edited by radroach; 11-06-2016 at 02:18 PM. |
hey you, yeah you <3
Drives: 2014 37J FR-S
YEAH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I damn freasked myself out. Forgot that the weather really impacts these wheels! Two weeks in a row damn TP light on! I added just 2psi, three days later again low TP! Then finally over filled by 3, and since then, been good!
Drives: 2013 Pearl White 6MT
Its cold? Where? It was almost 80 today in North Ga.
But I'll keep it in mind!
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I
at night and ate at sun rise |
#7 | |
![]() humfrz |
Drives: car
@RichardsFRS tonight's low is in the upper 40's
#10 | |
Drives: 2013 Scion FRS
Sent from my HTC6535LVW using Tapatalk |
#11 | |
"The rule of thumb is for every 10° Fahrenheit change in air temperature, tire pressures will change about 2% (up with higher temperatures and down with lower). This means that light-duty, standard-pressure tires (typically inflated to 30-50 psi) used in applications on cars, vans and light trucks will change by about 1 psi; where heavy-duty, high-pressure tires (typically inflated to 80-100 psi) used in applications on recreational vehicles, busses and trucks will change by about 2 psi." http://www.tirerack.com/winter/tech/....jsp?techid=73 Did you really have a 100 degree temperature change?
#12 | |
#13 | |
Famous Potatoes
Drives: '15 ultramarine
#14 |
Famous Potatoes
I had the opposite happen. It warmed up 10 degrees and my tires blew up from over inflation. Sucks!
| Tire Pressure and Temperature Gauges recommended for track use | Toyarzee | Tracking / Autocross / HPDE / Drifting | 16 | 01-26-2016 08:23 PM |
| Innovate MTX-D Oil Pressure/Temperature, full set-up | malave7567 | Interior Parts (Incl. Lighting) | 4 | 12-17-2015 06:10 PM |
| Oil Pressure and Temperature Guide Video | Dezoris | Engine, Exhaust, Transmission | 25 | 05-19-2015 02:51 PM |
| best tire pressure gauge (tire pressure question) | steveholt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 03-21-2015 10:27 PM |
| Plot your oil pressure vs temperature | Gords_zenith | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-22-2014 06:09 PM |
