Old 04-10-2018, 03:35 AM   #1
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Intermittent fuel pressure/signal drop (Fuel regulator prob?)
Ever since installing a DW300 fuel pump, DW 700cc injectors, Delicious Flexfuel kit w/ Mk1+ upgrade and my Greddy turbo kit ive been having random fuel pressure drops. Pressure will drop to 30+psi when im shifting low gears or slowing down to a light with foot off the gas. Tuner says the logs show a loss in signal/intermittent drop in pressure.
No problems with WOT logs, all values looking perfect. All with exception to this fuel pressure drop.
Ive read people say its the fuel regulator going out or dirty/kinked fuel sock stopping pressure. Anyone else have an idea what it may be?
The problem doesnt occur when im above 3k rpm or WOT. Only when im in low gears and in stop&go traffic. Problem exist when I’m using 91 or E85. The car also lurches back and fourth when this happens (kinda like if i was to step on the gas and let off repeatedly for one or two seconds). I also checked for vaccum leaks and all seems to be good.
Decimus is offline   Reply With Quote
Old 04-20-2018, 05:59 PM   #2
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
BUMP
Old 04-20-2018, 06:26 PM   #3
Grady
Grady's Avatar
Just had a lean fuel code issue with mine with low fuel pressure indication. Started off minor then got so bad the car would not start with our holding down the accelerator. Mine was a indication issue caused by moisture in the D box. Check location of box and make sure the wires are pointing straight down. Relocated mine after to the front of the fuse box with the wires down. Delicious was spot on wth help on this issue. Email Zach and let him know.
Same injectors, pump, kit on mine. Only difference is AVO turbo.
The Following User Says Thank You to Grady For This Useful Post:
Decimus (04-21-2018)
Old 04-21-2018, 04:40 PM   #4
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Thank you for suggestion!
Old 03-27-2019, 03:38 PM   #5
B.Pod
Drives: White Toyota GT86 '12
Hello Decimus,
Did you manage to solve your problem ? I think I have the same issue with exacly the same feeling but no modification installed on my car. I also incriminate my fuel pressure regulator but not sure because no low fuel pressure circuit log are available on this car.
B.Pod is offline   Reply With Quote
Old 03-27-2019, 04:27 PM   #6
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Originally Posted by B.Pod View Post
Hello Decimus,
Yea the problem was fixed for me when i changed out my delicious tuning flex fuel kit. The dbox started malfunctioning i guess and every time at 2k rpm ill somehow lose fuel pressure.
Since replacing the flexfuel kit fixed my issue, i didnt look further into it.
Old 03-27-2019, 08:38 PM   #7
B.Pod
Thanks for your answer... I am still looking for a solution
Fuel pump assembly: Fuel pressure regulator popping out sfruski Engine, Exhaust, Transmission 2 09-15-2017 10:39 PM
Fuel Regulator tofurun Forced Induction 9 01-09-2017 10:11 PM
Adding in line fuel pressure regulator KGZ86 Engine, Exhaust, Transmission 13 07-07-2016 06:15 PM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 07:21 AM
Fuel cut or bad ecu signal? love 4 boost Issues | Warranty | Recalls / TSB 8 07-02-2013 04:20 PM
