Old 03-20-2024, 09:02 AM   #43
Bergycheese348
Bergycheese348's Avatar
Drives: TRD Supercharged 2016 FR-S
Originally Posted by DocWalt View Post
What's your toe? Inner edge wear is almost always from toe and not camber.
Mine is just slightly out. I forgot the specific amount but it is very minimal
"Ooh, hang on. That is the throb of a turbocharged flat four engine. A sound which, all over the world, heralds the imminent arrival of a moran" -Jeremy Clarkson
T RD, Verus, Ace
Bergycheese348 is offline   Reply With Quote
Old 03-20-2024, 09:10 AM   #44
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
It's likely from the daily driving and slight toe out.
I was on -3.8 camber and 0 toe in the front. Daily the car between autocrosses with rotating in street tires for the non-race use. shagged the inside of the front tires in around 5K miles.
Breezio is offline   Reply With Quote
Old 03-20-2024, 12:30 PM   #45
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
and remember that slight toe-in turns into 0 or toe-out while driving down the road (assuming you have bushings still)
I have -5 camber and slight toe-in and I have "fine" wear even though the car is my daily.
Old 03-20-2024, 01:01 PM   #46
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
ah yeah, obviously, driving straight will burn the insides faster than track driving with negative camber
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 03-25-2024, 01:20 PM   #47
Bergycheese348
So, i guess for my case, what would you guys do for my alignment? 0 toe, same camber?
T RD, Verus, Ace
Old 03-25-2024, 01:55 PM   #48
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
0 front toe, yes.
The Following User Says Thank You to DocWalt For This Useful Post:
Bergycheese348 (03-25-2024)
Old 03-26-2024, 08:41 AM   #49
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Bergycheese348 View Post
My setup consists (at that time) TRD lip, skirts, canards. Verus UCW (mid to full AOA), hood vents, diffuser, spats. APR splitter (for the TRD lip) that is properly flat. AST 5100 suspension with 6k/6k Swift springs.
How are your front fender liners?
I am on Verus splitter, GTC-200, DL diffuser. Was on 6k/6K setup on T2’s and I would destroy my front fender liners. It basically felt like it was bottoming the front in high load corners and the car would always mid corner under steer.
Old 03-26-2024, 10:15 AM   #50
Bergycheese348
I am running 18x9.5 (forgot offset) wheels on 255/35/18 tires. In terms of the fender liners being damaged, the only damage on them is from the wheel just ever so slightly rubbing on the inside (more so rubbed the other smaller plastic fender thingy). Besides that I have zero rub up front, and in the rear I have the smallest bit of rub on the inside of the fender and has not rubbed through the liner.
T RD, Verus, Ace
Old 03-26-2024, 01:16 PM   #51
GrandSport
GrandSport's Avatar
17x8 with 35mm offset running 245/40/17 tires and steering limiter (for brake ducts) and I just ripped out a fender liner
Old 03-26-2024, 01:31 PM   #52
RedReplicant
Drives: None
If you're eating your fender liners fix your front damper length
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
DocWalt (03-26-2024)
Old 03-26-2024, 10:26 PM   #53
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They are not adjustable with the RCE/KW’s that I am aware off. I have them set to not touch with the Annex’s.
Edit: Now that I am thinking about it I could probably double stock bumpers or make a rubber puck to limit up travel.
Old 03-27-2024, 12:10 AM   #54
jflogerzi
jflogerzi's Avatar
why not get stiffer springs? go to 7k up front 8k rear?
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Old 03-27-2024, 06:33 AM   #55
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
I went up to 8k front 9k rear for my Verus UCW. I was also told that there are road racers that run 11k/12k as well.
RT-BRZ is offline   Reply With Quote
Old 03-27-2024, 08:08 AM   #56
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I did, but ended up buying and installing your old CSP’s.
FS: SARD LSR Style Carbon wing **wing only* brzzy Canada Classifieds 3 03-23-2017 09:58 PM
Does anybody have seibon gt wing or apr gtc200 universal wing on their car? spicyricecake Cosmetic Modification (Interior/Exterior/Lighting) 6 03-17-2016 08:38 AM
FS: Used OEM Limited Wing - Dark Grey Metallic - with STi wing gurney Enalband24 Exterior Parts (Aero, Lighting, Etc.) 10 01-03-2016 12:24 PM
Gauging Interest: Wing or GT Wing?! awang0528 Exterior Parts (Aero, Lighting, Etc.) 3 05-01-2013 12:12 AM
