#43 |
Drives: TRD Supercharged 2016 FR-S
Mine is just slightly out. I forgot the specific amount but it is very minimal
"Ooh, hang on. That is the throb of a turbocharged flat four engine. A sound which, all over the world, heralds the imminent arrival of a moran" -Jeremy Clarkson
T RD, Verus, Ace |
#44 |
Drives: 2017 BRZ series.yellow
It's likely from the daily driving and slight toe out.
I was on -3.8 camber and 0 toe in the front. Daily the car between autocrosses with rotating in street tires for the non-race use. shagged the inside of the front tires in around 5K miles. |
#45 |
Drives: '22 BRZ
and remember that slight toe-in turns into 0 or toe-out while driving down the road (assuming you have bushings still)
I have -5 camber and slight toe-in and I have "fine" wear even though the car is my daily.
#46 |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
ah yeah, obviously, driving straight will burn the insides faster than track driving with negative camber
2014 BRZ: WRL Build (GP2) Gutted, caged, coilovers, AP enduro, etc-
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
#47 |
So, i guess for my case, what would you guys do for my alignment? 0 toe, same camber?
T RD, Verus, Ace |
#48 |
Drives: '22 BRZ
0 front toe, yes.
| The Following User Says Thank You to DocWalt For This Useful Post: | Bergycheese348 (03-25-2024) |
#49 | |
Drives: Crapcan
I am on Verus splitter, GTC-200, DL diffuser. Was on 6k/6K setup on T2’s and I would destroy my front fender liners. It basically felt like it was bottoming the front in high load corners and the car would always mid corner under steer.
#50 | |
T RD, Verus, Ace |
#51 | |
#52 |
Drives: None
If you're eating your fender liners fix your front damper length
| The Following User Says Thank You to RedReplicant For This Useful Post: | DocWalt (03-26-2024) |
#53 | |
Drives: Crapcan
Edit: Now that I am thinking about it I could probably double stock bumpers or make a rubber puck to limit up travel.
#54 |
why not get stiffer springs? go to 7k up front 8k rear?
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
#55 |
Drives: 2013 Subaru BRZ
#56 |
Drives: Crapcan
I did, but ended up buying and installing your old CSP’s.
| FS: SARD LSR Style Carbon wing **wing only* | brzzy | Canada Classifieds | 3 | 03-23-2017 10:58 PM |
| Does anybody have seibon gt wing or apr gtc200 universal wing on their car? | spicyricecake | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 03-17-2016 09:38 AM |
| FS: Used OEM Limited Wing - Dark Grey Metallic - with STi wing gurney | Enalband24 | Exterior Parts (Aero, Lighting, Etc.) | 10 | 01-03-2016 01:24 PM |
| Gauging Interest: Wing or GT Wing?! | awang0528 | Exterior Parts (Aero, Lighting, Etc.) | 3 | 05-01-2013 01:12 AM |
