Old 11-05-2023, 01:01 AM   #1
Rex1585
CAD file for subframes
I'm looking to see if anyone has CAD files for the front or rear subframes.
I'm probably going to have to make both to work within the design parameters off my project. Let me know what you guys have!
Thanks
Sent from my Pixel 7 Pro using Tapatalk
Rex1585 is offline   Reply With Quote
Old 03-25-2024, 01:42 PM   #2
ML
ML's Avatar
Drives: 13 White MT FR-S
Thanks
I looked through onshape and couldn't find anything. did you have any success?
Old 03-25-2024, 01:50 PM   #3
Rex1585
I've had zero luck even with reaching out to. Q few people. I'm probably going to have to make my own scan and release it to the community
Old 03-25-2024, 01:53 PM   #4
ML
ML's Avatar
I would be interested and can throw some beer money to you if you make it happen. I'm investigating the feasibility of swapping an rx8 front subframe into this chassis and that would help speed it along.
Old 03-25-2024, 01:59 PM   #5
Rex1585
Cool. I'll see what I can come up with, my subframe is pretty modified from what it was, but I *might* be able to clean up the scan a little bit to remove what I added.
Old 03-25-2024, 10:53 PM   #6
Luns
Drives: 2017 GT86
RX8 has a narrower engine bay. I don't imagine the RX8's subframe can fit without major surgery to the body.
This thread killed any fantasies I may have harboured of bolting in a double-wishbone front suspension:
https://forums.nasioc.com/forums/sho....php?t=2887287
That said, for what I'm seeing of ToyoRati, the modifications necessary don't seem out of the question.
Luns is offline   Reply With Quote
Old 03-26-2024, 02:23 AM   #7
ML
ML's Avatar
I'm familiar with that build but I didn't realize how close my logic had landed with his. I want to move my k24 that far back and add the double wishbone, but I want to modify the subframe more than the chassis
Old 03-26-2024, 11:28 AM   #8
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I will have a scan of a stock rear subframe in the next couple of weeks. Ordered a new one the other day to scan for designing some diff swap parts (GM 8.6" or Ford Super 8.8"). I don't have a front subframe but if someone were willing to bring me one I can scan it.
kask2_6.0 is offline   Reply With Quote
Old 03-26-2024, 11:31 AM   #9
Rex1585
Send me a message. I will gladly have one shipped to you.
Old 03-26-2024, 01:35 PM   #10
ML
ML's Avatar
I can chip in some money
BIN FILE TO XML FILE? Nobunnyhere.86 Software Tuning 3 10-06-2017 07:46 PM
2017 86/brz ecu def file available? Chr15 Software Tuning 6 11-24-2016 10:23 PM
OFT - Mode file not found. Cannot create a tuning file. focobrz Software Tuning 11 07-17-2015 09:22 PM
which OFT map file to use? BPB stg2 Corradooo Software Tuning 2 06-29-2014 04:09 PM
custom subframes (cross members) 7thgear Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 12-29-2013 12:56 AM
