i'm sorry, what?
Drives: Canada
custom subframes (cross members)
The impreza has a small market, mainly for the pro racers and rally guys
but i'm wondering who will be the first to start producing these for the FRS they are lighter, stronger, and allow you to relocate the inner pivot points of control arms and what not
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
What would be the advantage of relocating the control arms?
i'm sorry, what?
Drives: Canada
same idea as the drop spindles/roll correction components
you get to drop the car while maintaing OEM geometry
Weight Nazi
Ah, ok. I'd be sold on it just from the weight and strength benefits alone, assuming they were what I'd consider a good cost:benefit.
#5 | |
i'm sorry, what?
Drives: Canada
i have seen documented step-by-step rocesses of people building these, it's not rocket science and if you keep it simple anyone that can weld would be able to make one. MSI is the most well know for Subaru's (but also stupid pricey), they claim 50% weight reduction over OEM. i'd post a link but i'm worried the mods are gonna hachiroku on my ass. You can google em, "MSI Impreza Rear Subframe" for more info.
Do want!! Thought about getting one to replace the rusting subframe on my STi.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
Weight Nazi
Oooph! Maybe later...
Giving multiple attachment points for the upper control arm also lets you tweak the camber curve as well, which can be a huge benefit to matching the curve to your suspension travel and spring rate.
A longer arm with the inner pivot further inboard will keep the same alignment, but give less camber gain, a shorter arm with the inner pivot further outboard will give more camber gain.
Drives: FR-S Whiteout
I'm sure when the SCCA production racing guys (or any other amateur racing class that allows this) start playing with this car is when you start seeing these on the market.
Intent > Content
cowardice is the mother of cruelty. |
#10 | |
Drives: Scion FR-S
#11 |
i'm sorry, what?
Drives: Canada
a frame what?
this is a rather critical part for the die hard handling enthusiast. Price isn't astronomical when you consider the benefits and the cost of all the smaller parts you would get to even come close to getting similar results.
#12 |
Drives: They have four wheels
Don't really think so w/ that complexity and load requirements. You could certainly try but I doubt it would be safe let alone even begin to turn a profit if you could. That's assuming use of cheaper wet carbon which would likely be even heavier and more unwieldy than this piece. Dry carbon would be 4-5 times more expensive at least.
Why would you even want to? Are you trying to decrease relaibility? CF is not the answer to everything. Notice the absence of CF wheels in F1? Even Dymag's website doesn't even list CF wheels for cars anymore. |
#13 |
Weight Nazi
Carbon fiber also flexes a lot more per thickness. To make it equally stiff, it would be so thick the weight savings wouldn't be nearly as substantial, plus the cost would go up. And yes, prepreg would be death-expensive.
#14 |
Drives: EVO
Actually, uni-axial dry carbon with the right laminate design is stiffer then steel for a given thickness. But composites aren't about thickness anyway as, if you are smart, you fill layers of composites with super light material that simply keeps the layers spaced a certain distance apart. You would also build it as a monocoque type structure using surface loads instead of a spaceframe structure like you would with metal. But there is NO WAY IN HELL you are building a structural carbon subframe for $1200. Maybe you could overlay an OEM subframe with wet carbon for that much to make it look like a carbon subframe.
![]() The fact that all the arm pivots are located on the subframe and not in the unibody is a BIG advantage here as you can do just about anything with geometry. Roll center, anti-squat, camber and toe curves...Everything can be changed. |
| Cross country trip | roflcopter | Southern California | 5 | 03-04-2013 10:22 AM |
| Car shipped cross country | SanDiegoFRS | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 02-07-2013 04:39 PM |
| Custom BRZ Parts for members | gdi2290 | BRZ First-Gen (2012+) — General Topics | 56 | 10-07-2012 10:35 AM |
| Formula Cross? | Mishimoto | Other Vehicles & General Automotive Discussions | 8 | 08-13-2012 08:08 PM |
| WOR Auto Cross June 3rd | Brett | Tracking / Autocross / HPDE / Drifting | 5 | 06-01-2012 05:23 AM |
