Old 04-11-2023, 10:48 AM   #127
Racecomp Engineering
Originally Posted by jimgreen83 View Post
Has anyone put B8’s on a GR86? I put some on my GT86 under a year ago and wondering about stripping that car since the GR86 arrived earlier than expected.
At least 1 person has done this along with 1st gen springs.
- Andrew
Old 04-11-2023, 10:49 AM   #128
Posted a little tech video where I talk about inverted struts using a Bilstein B6 as an example. I take it apart so you can see the bumpstop and grease inside.
Like/share/subscribe etc. plz because I made it through a ton of innuendo after a lot of takes.
- Andrew
The Following 7 Users Say Thank You to Racecomp Engineering For This Useful Post:
beanswv17 (04-12-2023), bhmax (05-09-2023), gen3v8 (04-11-2023), new2subaru (04-11-2023), norcalpb (04-17-2023), RT-BRZ (04-11-2023), RToyo86 (04-11-2023)
Old 03-09-2024, 06:08 PM   #129
JIM THEO
Drives: BRZ 2018
I installed yesterday the B6s with the tS pink springs and new top mounts, pedders fronts subaru rears.
My first impression is that they are more "tight" and slightly harder than the tS Sachs, give the car a more solid feeling, absorb better road imperfections at high speeds but are slightly less comfortable at very low speed bumps and potholes, but have much better rebound!
Their negative is they increase the ride height, tomorrow I'll measure by how much.
So far so good, I'll drive the car on mountainous roads to see it's overall difference but I am convinced they are better than the OEM Sachs.
JIM THEO is offline   Reply With Quote
Old 03-09-2024, 06:23 PM   #130
LancePower
Drives: 2020 BRZ tS
I have B8's paired with Eibach Pro-Kits and have the same observation.
Slow speeds or large imperfections are harsh, but the higher speed stuff feels more controlled.
How many miles does it take to break-in a shock? I still may not have hit that mark yet.
LancePower is offline   Reply With Quote
Old 03-09-2024, 07:27 PM   #131
JIM THEO
Drives: BRZ 2018
I am not sure but I already did a 300Kms road trip mainly on good roads
Old 03-11-2024, 12:04 PM   #132
JIM THEO
Drives: BRZ 2018
I drove yesterday the car on bad roads and it is a lot stiffer, more harsh and unfortunately ride height has gone up ~1cm!
Old 03-11-2024, 02:36 PM   #133
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I observed the same thing with my yellow springs when I swapped out OEM shocks. Ride height looked higher. I can try snapping a picture but I think they may have settled a bit since installing them roughly 60-70,0000km ago.
I have similar experience with ride quality. high speed stuff is good but low speed big bumps are quite harsh, the added spring rate isn't helping there.
Old 03-11-2024, 02:58 PM   #134
And the internal bumpstops on the Bilsteins. It is a little bit annoying to open them and modify them, but the more I've thought about it, the more I think it's worth it. You just have to be careful.
- Andrew
Old 03-11-2024, 04:39 PM   #135
norcalpb
norcalpb's Avatar
- Andrew
Do you mean remove the Bilstein bump stops and replace them with oem or Eibach?
Old 03-11-2024, 05:50 PM   #136
Those won't fit inside the fronts, so the only real option is to trim the Bilstein bumpstops.
I wish there were another option but I searched a LOT and came up empty. Trimming the fronts isn't ideal but I now think it's better than not doing it depending on the spring.
- Andrew
JIM THEO (03-12-2024), norcalpb (03-11-2024)
Old 03-11-2024, 06:52 PM   #137
JIM THEO
Drives: BRZ 2018
I wish there were another option but I searched a LOT and came up empty. Trimming the fronts isn't ideal but I now think it's better than not doing it.
- Andrew
I wish you have write this before I install the B6s Andrew, I am not going to remove it now
Old 03-11-2024, 07:48 PM   #138
RToyo86
RToyo86's Avatar
Yes I recall considering that during installation.. maybe I'll give that a go sometime especially if it can help with larger impacts.
Old 03-11-2024, 09:34 PM   #139
I would have considered it optional with near OEM height springs.
Part of the concern is that anytime you're taking apart a damper to get to something internal, there's a possibility that someone will make an expensive mistake. It's not difficult to do it right, but...even with a shop I'd be nervous about them making a mistake. The other part is I wish there was a full replacement bumpstop available but I just can't find any. Cutting a bumpstop is a compromise, though it may still be an improvement.
- Andrew
Old 03-11-2024, 09:53 PM   #140
JIM THEO
Drives: BRZ 2018
- Andrew
Which points me to ask you another question, what is your opinion regarding the B6s paired with the original STI springs from the STI Bilstein kit? https://www.sti.jp/parts/subarubrz_z.../ST20330AS010/
I don't think there is much difference between the STI Bilsteins and the B6s, ok they are slightly longer and perfectly valved for the STI pink springs, but what about ride height, will the 15mm lowering from the STI kit correct the B6 height increase?
Or the lowering on the STI kit comes from the struts not the springs although they look similar with the B6s?
Ιt's easier for me to sell the tS pinks and replace them with the STI/Bilstein pinks that I guess will be slightly harder and better mated with the Bilsteins
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-04-2017 12:22 PM
AVCS Explained Rennmeister Engine, Exhaust, Transmission 3 03-15-2016 04:12 AM
STX Bilstein Double Adjustable Package - Bilstein PSS with Dual Bleed Shafts FRSport.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 02-25-2016 01:50 PM
Ok, who has stories that can't be explained? husker741 Off-Topic Lounge [WARNING: NO POLITICS] 143 11-26-2014 06:25 AM
Part of the problem explained. Suberman CANADA 95 01-28-2014 02:26 PM
