Old 02-22-2016, 03:48 PM   #1
FRSport.com
FRSport.com's Avatar
Drives: Scion FR-S Subaru BRZ
Send a message via AIM to FRSport.com
STX Bilstein Double Adjustable Package - Bilstein PSS with Dual Bleed Shafts
We just wanted to share with you guys our set up for the 2016 STX (Street Touring Xtreme) Year.
We modified a set of non-adjustable Bilstein PSS (B14) to a Dual Adjustable Coilover with the Bilstein Dual Bleed MDS Shafts.
Paired with the Raceseng Top Hats and DIF Upper Spring Hats the Swift Springs can make sure we get the optimum travel we need.
We are in development with some extended top hats in the front so we can lower the car more and run a more aggressive alignment.
Here's some photos!
The entire Kit:
Front
Front Adjusters
Rear
Rear Adjusters
Yes, both front and rear coilovers are co-axial to the hats and upper spring perches.
If you guys have any other questions, feel free to ask.
Or email
Adrian@frsport.com
FRSport.com is offline   Reply With Quote
The Following 9 Users Say Thank You to FRSport.com For This Useful Post:
Bach415 (02-22-2016), DocWalt (02-24-2016), DustinS (02-22-2016), e1_griego (02-22-2016), Iceman (02-23-2016), Krispeee (02-23-2016), Racecomp Engineering (02-22-2016), renfield90 (02-23-2016), Shankenstein (02-22-2016)
Old 02-22-2016, 04:35 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
What are spring rates? What is minimum drop that's possible with these?
Old 02-22-2016, 04:51 PM   #3
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
That's an awesome package, and exactly what many STX competitors are looking for. Out of the box quality, and all the components to allow for cheap/easy tinkering (fine-tune for an important venue, overhaul for the season, etc).
Any chance you guys have some representative dyno plots?
Who loves data?
Shankenstein loves data!
Is it true?
I do... I do... I doooo~!
EDIT: Just saw their C-Street version of this product: LINK to FRSport It's about the exact same price as Vorschlag's MCS TT2 system. Either way, Street class has some legit options.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following User Says Thank You to Shankenstein For This Useful Post:
finch1750 (02-23-2016)
Old 02-23-2016, 01:47 PM   #4
FRSport.com
Via Bilstein's stock rates,
The lowering range falls between 30mm to 50mm.
And as Far as spring rates go, usually suggest a 7/8 combo.
but spring rates are all based off of the driver and tire and other factors.
Old 02-23-2016, 01:55 PM   #5
FRSport.com
Who loves data?
Is it true?
As far as a dyno sheet will go,
Unfortunately we will not post a dyno sheet since each and every single kit we produce will have a different graph. We base the valving on all the different variables that a person will be using. (spring rates, sway bar, tire size, tire compound, wheel width, class, and so on)
So all the graphs will look different.
The shocks use the Bilstein COB Digressive piston so it will show a digressive curve.
Here is an example from a set of Bilstein B6 Miata Shocks we've done for one of our employees.
These look similar to the FRS kit but with adjustability and a more aggressive curve.
Old 02-23-2016, 02:04 PM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Who loves data?
Is it true?
I do... I do... I dooooo
you know youre a suspension nerd when...
The Following User Says Thank You to cdrazic93 For This Useful Post:
Calum (02-23-2016)
Old 02-23-2016, 03:13 PM   #7
Shankenstein
Frosty Carrot
Me, in real life (Fallout NV style):
The Following 6 Users Say Thank You to Shankenstein For This Useful Post:
Calum (02-23-2016), Captain Snooze (02-25-2016), cdrazic93 (02-23-2016), Cole (02-24-2016), finch1750 (02-23-2016), Racecomp Engineering (02-23-2016)
Old 02-24-2016, 06:16 PM   #8
Devil 86
Devil 86's Avatar
Drives: Ultramarine FR-S
Mmmmmmmmmmm mmmm that looks so good. Will this ever be sold to the general public?
Devil 86 is offline   Reply With Quote
Old 02-24-2016, 08:43 PM   #9
strat61caster
strat61caster's Avatar
I'd bet anybody who calls FRSport up can arrange to get a set built for them provided the check clears.
Edit: You may never be able to just open up their website, hit three buttons and have them show up a few days later.
ineedyourdiddly
Cole (02-24-2016)
Old 02-25-2016, 01:49 PM   #10
FRSport.com
They are available anytime!
Just gotta give us a call.
Old 02-25-2016, 01:50 PM   #11
FRSport.com
As far as being to click on our site and having it show up in 3 days,
They are a bit more complicated than that.
We like to have a personal phone call with the driver and our tech that way they can figure out what is best for the shocks.
We will discus rates, tires, wheel sizes, what the car is used for, and so on.
That way the customer gets exactly what they want!
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-04-2017 12:22 PM
Bilstein B6s and B8s speargunsandracecars Suspension | Chassis | Brakes -- Sponsored by 949 Racing 61 05-09-2014 09:04 PM
Bilstein pss b14 adjustable coilovers FRS-HHH Brakes, Suspension, Chassis 19 04-17-2014 07:42 PM
Bilstein I-RC C3 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-16-2013 12:45 PM
bilstein PSS mokinbird87 Southern California 1 10-29-2013 11:12 PM
