Old 11-28-2023, 10:56 AM   #169
e1_griego
e1_griego's Avatar
Drives: Many
I have everything from +35 to +42, and I usually run a 3-5mm spacer with everything (with so much camber it's all fine).
I couldn't tell a difference in amount of rubbing between any of them and it smokes a fender liner maybe once a year (~250ish runs) regardless lol.
e1_griego is offline   Reply With Quote
Old 11-28-2023, 01:17 PM   #170
jcaserta
Drives: 2015 FR-S
Originally Posted by cmiovino View Post
This is interesting. Read through your journal thread and saw some others having slight rubbing issues with +35's on 245's. Weird. I see people on here and the other STX setup threads running +42 without spacers. Probably a 40/60 mix on +42/35. If yours and others are rubbing with +35, I don't know how they're getting away +42. Possibly different ride heights. Even then, if it's rubbing on the inner fender, that doesn't really help.
Maybe going with +35 isn't a bad idea then.
First of all it's only 7mm we're talking about so other factors can matter more, but of course it helps.
Second of all whether you rub depends on your 1) ride height 2) alignment 3) springs and shocks 4) level of grip and 5) how bumpy the site is.
If a good driver on an ideal setup is cornering hard and hits a bump mid corner, that's going to take a lot to not rub. Whereas if the site isn't bumpy, it'd be much less likely.
Anyway I run +35mm also with a 5mm spacer in front, with 4.8 camber and 245 yoks. I usually don't rub but sometimes will rub a little where the fender liner goes over the brake line at high grip bumpy sites. The rear I don't have a spacer, and no rubbing no matter what.
I'd just do 35mm on a gen1.
jcaserta is offline   Reply With Quote
The Following User Says Thank You to jcaserta For This Useful Post:
autoracer86 (11-29-2023)
Old 11-28-2023, 02:26 PM   #171
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Thanks, I'm edging towards +35 now. I kinda don't love the whole stancey boi look, but I guess with ~4 degrees of camber up front, it won't look bad. I have 3mm spacers on the car right now with ARP studs, so if it needs a bit of 'tuning' to get mine to fit, I have some wiggle room.
I did just pick up some RCE SS-1's today for a bargain. 1500 miles. Can't wait to get this setup for STX-lite. After 4 years in DS, I've had enough.
My other option is getting the +42 and using the 3mm spacers to get around a +39. Problem is, if some people are rubbing on +35... eh, +39 won't be enough.
cmiovino is offline   Reply With Quote
Old 12-22-2023, 09:35 PM   #172
kraftyone
kraftyone's Avatar
Drives: 2020 Subaru BRZ Limited PP
I posted earlier in the thread but maybe I can update. I won the prosolo national championship this year and was winning after day 1 of solo nats before Mr Mudge here kicked my ass day 2 and took the win, I ended up 2nd at nats.
-2015 FR-S
-MCS 2 way remote with 6k/9k springs
-Karcepts sway bars front and rear. Large center section for the rear bar.
-Verus rear LCA STX legal version
-OS Giken LSD 1.5 way tuned by Shaftworks
-17x9 +35 RPF1 with 245 A052. Running a 3mm spacer in front
-Skunk2 intake with MAF insert removed
-JDL EL 4-2-1 header
-JDL overpipe
-JDL ultra quiet midpipe
-stock catback
-ECUtek tuned by xero limit
-Whiteline rear subframe bushings, rear diff bushings, and positive shift bushing
-Perrin motor mounts
-Master cylinder brace
-Ferodo DS2500 brake pads, stock calipers, castrol SRF fluid
-Forester oil cooler for track day bro time
-Camber 4.8F/2.6R
-Stock caster
-Toe 0F/0.33 degrees total rear toe in (that's slightly over 1/8" toe in, 0.14" or so)
-Ride height 12.95" F/ 13.2" R hub to fender metal
Still stock seats, stock exhaust, stock brakes. I just got a HKS spec-L delivered to my front door so that's going on for next year . I'll probably get the AP sprint kit over the winter.
John what model verus LCA are stx legal?
Sent from my SM-S916U using Tapatalk
kraftyone is offline   Reply With Quote
Old 12-28-2023, 04:12 PM   #173
ka-t_240
They sell a version with rubber bushings vs spherical.
ka-t_240 is offline   Reply With Quote
The Following User Says Thank You to ka-t_240 For This Useful Post:
kraftyone (01-14-2024)
Old 01-01-2024, 11:23 PM   #174
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
This: https://www.ftspeed.com/products/a00...nt-anodized-bl
Plus this: https://www.ftspeed.com/products/a00...-inboard-mount
Breezio is offline   Reply With Quote
The Following User Says Thank You to Breezio For This Useful Post:
Old 01-01-2024, 11:32 PM   #175
Breezio
Breezio's Avatar
I run 255/40 Yoks on my 2017.
-4.3 camber up front. -1.7 camber in rear.
I have a +35mm set of wheels and a +40mm set of wheels.
No spacers.
The +35mm setup I had a very tiny but of rub on the uppermost mounting tab for the rear bumper, shaved a few mm's off and no more rub.
The +40mm setup I get a pretty strong rub at full steering lock on the inside fender liner and 'frame'.
No other rubbing and on our primary lot I've had the car airborne mid corner.
Old 01-05-2024, 06:57 PM   #176
jcaserta
Drives: 2015 FR-S
Yep or alternately you can just buy the polyurethane version from verus directly if you pick the poly option here https://www.verus-engineering.com/sh...1#attr=204,100
The Following 2 Users Say Thank You to jcaserta For This Useful Post:
Breezio (01-23-2024), kraftyone (01-14-2024)
Old 04-23-2024, 01:26 PM   #177
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Good to finally meet a bunch of y'all at Charlotte, even if I was breaking up the Twin party this weekend! Was planning on driving my car, but last minute change of plans while my shocks are off for a refresh. Lead to some confusion at reg where my wife and I somehow ended up registered in my BRZ in STX instead of her RX-8.
My fastest runs for comparison:
The Following User Says Thank You to DocWalt For This Useful Post:
RT-BRZ (04-23-2024)
Old 04-26-2024, 12:25 PM   #178
steverife
Drives: 2016 Scion FRS
Do we know how much toe changes by raising (or lowering) the car by say half an inch?
steverife is offline   Reply With Quote
Old 04-27-2024, 11:03 AM   #179
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
From 27” down to 24” at the rear fender arch each inch of ride height lowered netted me a 0.04” increase in toe in.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Muffled (06-24-2024), steverife (04-28-2024)
Old 06-23-2024, 09:07 PM   #180
kraftyone
kraftyone's Avatar
So this year I went from -3.6* front camber to -4.7*. I have found that when transitioning in slalom or during sweepers I have developed oversteer. I am assuming do to the increased front camber. Question is what adjustments to make to bring back rear grip? Currently running whiteline 20mm front bar on soft 16mm rear bar in middle.
Old 06-24-2024, 10:51 AM   #181
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
Many many variables here, but set the front bar to stiff?
Autocross nut
AustinTX is offline   Reply With Quote
Old 06-24-2024, 11:11 AM   #182
cmiovino
cmiovino's Avatar
A couple things. Front bar could go to stiff, rear bar could go to soft. Personally, I'd set the rear to soft. I don't see the need for any larger/stiffer than the 15mm 2017+ on these cars for the rear.
Beyond that, look at your ride height and rake. Most people run a 1/4-1/2" rake at the pinch welds. You'll need more rake with a square spring setup. Less if you're running a staggered spring setup with like 5/7k or 5/9k.
Sidenote: What's everyone running for ride height in 2024? I've been searching over and over on here and it greatly varies. Earlier like pre-2020, people were running ~13.5" center hub to fender and it's gotten down as low as about 12.75" recently as a trend.
STX setup sharing thread (2022) Autoxer62 Tracking / Autocross / HPDE / Drifting 204 06-15-2023 03:34 PM
STX setup sharing thread (2021) Autoxer62 Tracking / Autocross / HPDE / Drifting 366 12-07-2021 02:57 PM
STX setup sharing thread (2020) Autoxer62 Tracking / Autocross / HPDE / Drifting 389 12-29-2020 02:40 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 12:27 PM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 12:30 PM
