Old 12-10-2023, 12:26 AM   #15
Compelica
Compelica's Avatar
Drives: 86 GT
Originally Posted by norcalpb View Post
Have you considered creating a cover plate for the oil pan opening like the GR86 has, or even some of the aftermarket options? Could potentially help with overall flow.
Personally I’m part of the hood vent gang (with a gr86 skid plate on my 2013) but I’m really interested in what you have going on here.
Ah wasn't aware that the GR86 underpanel is a direct fit for the older twins.
Not sure what you meant by improving overall flow, as the ZN6 oil pan opening would also serve as a outlet for air to flow out of the engine bay.
On creating a cover - probably not worth the work at this point (and you could just get a used GR86 panel anyway).
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 12-10-2023, 12:55 AM   #16
norcalpb
norcalpb's Avatar
It's not exactly a direct fit, you need to get the GR86's front sway bar mounting brackets and it's OEM front chassis bracing ~ $120 for all that.
You could be right about the oil pan opening venting heat, but in my amateur opinion it seems like the opening is far too big to create a pressure differential that will allow effective air evacuation, especially compared with the "louvered" flaps you have created. I'm just thinking that if that area was covered, your louvers would siphon out heat even more than they already are. Could be completely wrong about that though. Would only require some sheet metal and 3 screws for testing though!
Old 12-10-2023, 06:57 AM   #17
Compelica
Compelica's Avatar
Drives: 86 GT
I see your point on the oil pan opening. Possibly that may happen on idle or low speed driving, but once highway speeds are attained that oil pan opening would possibly help evacuate air out of the bay.
A smoke machine would be great to see how the air exits...
Old 12-10-2023, 09:27 AM   #18
gpvecchi
gpvecchi's Avatar
@Compelica, I really appreciate your job, but would't it be easier to buy the vented Beatrush panel?
Old 12-10-2023, 10:57 AM   #19
Compelica
Compelica's Avatar
Drives: 86 GT
Given the price of the Beatrush panel including shipping, getting the stock one done at a shop will be less than 10% of the overall cost.
The Following 2 Users Say Thank You to Compelica For This Useful Post:
gpvecchi (12-11-2023), x808drifter (12-10-2023)
Old 12-10-2023, 11:05 AM   #20
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
$200+ plus shipping vs some side cutters.
Guess your time/effort isn't worth much.
Old 12-10-2023, 11:23 AM   #21
Compelica
Compelica's Avatar
Drives: 86 GT
Where I live, labor is in a way, affordable but products are expensive - it cost me approx $24 to get it done at a metal works shop with laser cutting and a machine to do the bending.
The Following 3 Users Say Thank You to Compelica For This Useful Post:
gpvecchi (12-11-2023), NoHaveMSG (12-12-2023), x808drifter (12-11-2023)
Old 12-11-2023, 12:52 AM   #22
gpvecchi
gpvecchi's Avatar
Unfortunately, labour price is not the same everywhere...
Old 12-11-2023, 02:32 AM   #23
x808drifter
LMGTFY
My point being this something someone could do on their own for free.
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
blsfrs (12-11-2023), NoHaveMSG (12-12-2023), Ultramaroon (12-11-2023)
Old 12-12-2023, 02:32 AM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It wouldn’t be pretty but I could replicate that with my 4 1/2” cutoff pretty quick.
x808drifter (12-12-2023)
Old 12-12-2023, 03:37 PM   #25
Ernest72
I did this a long time ago just for fun. Also needed to bang a bend in the thing to stop rubbing on the jdl header. I also drilled holes in my side emblem thing. Not sure it does anything but I have felt heat coming out of it parked after driving. Just street, no track so I don’t see any ill effects. Thanks for your testing.
The Following User Says Thank You to Ernest72 For This Useful Post:
Compelica (12-26-2023)
Vented vs non vented rotor quick question!! Robbie7c BRZ First-Gen (2012+) — General Topics 4 01-15-2023 10:35 AM
WTB: Vented/Stock Hood MotoX16 Want-To-Buy Requests 4 11-09-2020 09:59 AM
Vishnu Looking for a 100% stock 6MT to do testing Robert@Openflash Northern California 4 04-05-2014 11:05 AM
Stock intake tract flow testing? zooki Engine, Exhaust, Transmission 1 01-24-2013 10:34 PM
extended DDPR stock FR-S Dyno testing Illusive Engine, Exhaust, Transmission 5 08-26-2012 10:20 AM
