Old 01-14-2023, 09:25 PM   #1
Robbie7c
Drives: 2013 Subaru BRZ
Vented vs non vented rotor quick question!!
So I’m in the middle of doing brakes on my 2013 Subaru BRZ. My car has the vented rear rotors, and I have the correct rotors to replace them but for whatever reason the parts store gave me the pads for non vented rotors. I definitely can’t use the new steel sheet metal sliders that they come with since it would rub on the rotor and simply don’t fit. But the pads are only slightly different they seem just a bit smaller but it looks like where they slide in the grooves is pretty well the same.
So my question is, is there any reason I can’t just clean up and reuse the old sliders and use the new pads? Or maybe I should just wait till Monday and get the proper parts?
Robbie7c is offline   Reply With Quote
Old 01-15-2023, 03:29 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Pretty sure the parts shop gave you the wrong pads since AFAIK these cars never came with solid rears.
I'd just wait.
Old 01-15-2023, 08:51 AM   #3
Ohio Enthusiast
Drives: 2018 BRZ
Nitpick, they did come with solid rear rotors in Europe and Japan (and perhaps other markets) in the lowest ("tuner") trim levels. They never came with them in the North America, though.
Ohio Enthusiast is offline   Reply With Quote
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
x808drifter (01-16-2023)
Old 01-15-2023, 10:04 AM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
as long as the old sliders are well greased yet, and the boots are in great shape with no tears, they're fine to re-use.
but i would make sure to get the right pads. rear brakes don't need to be done as often due to the brake bias, so you'll likely be stuck with something not working correctly later for a very long time otherwise.
Old 01-15-2023, 10:35 AM   #5
Robbie7c
Ok sounds good thanks guys. I’ll wait and get it done properly.
Vented Fenders Bergycheese348 Cosmetic Modification (Interior/Exterior/Lighting) 5 10-25-2022 11:28 AM
Vented Hoods j_ros94 Cosmetic Modification (Interior/Exterior/Lighting) 23 09-05-2020 01:45 PM
Vented hood D K Exterior Parts (Aero, Lighting, Etc.) 2 04-12-2018 06:26 PM
VIS vented hood K_Stout Cosmetic Modification (Interior/Exterior/Lighting) 0 04-22-2015 06:22 PM
vented hood? 75 carrera Cosmetic Modification (Interior/Exterior/Lighting) 2 07-02-2012 09:57 PM
